99 powerstroke - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 7.3ford350, this thread has received 24 replies and been viewed 1682 times.
post #1 of 25 (permalink) Old 05-13-2007, 05:07 AM Thread Starter
99 powerstroke
well i am looking to buy a 99-02 powerstroke. i found a 99 the other day and went and test drove it and it seamed as if everything was ok. the build date on it was 12/98. is that an early or later 99? do these trucks have a any certin problems with them other then reg stuff ( oil, fuel filter stuff like that? is there anything i should be watching out for. just help me out becouse i dont want to buy something that gonna cost me in the long run. ohhh and i currently selling the truck in my sig..thanks guy for all the help
7.3ford350 is offline
post #2 of 25 (permalink) Old 05-13-2007, 07:49 AM
That should be a late 99. Nothing really any different maintenance-wise than your 97.
gregrob is offline
post #3 of 25 (permalink) Old 05-13-2007, 08:52 AM
If I remember right the cut off date was 12-7-98
GENE
99 F450 CC, AT, XLT LB Shortened Frame 3.5 , John Wood Tranny & TC , H2 Turbo , DI 6 Pos Custom Chip , Mini-me's , Custom Intake , Idle Speed Control, Turbo Temp Monitor , 4 Down Pipe, 5 Exhaust , Isspro Gauges , Power Pedal Mod. Fuel Regulator System , Dual Stock Fuel Tanks. White Ext , Grey Int , Alcoa 19.5 Rims Factory Center Caps , Cowl Induction Hood , Dual Highway Products Tool Boxes , 5th , Wheel, Goose Neck, Pintle & Class 5 Hitches.
Builder and Driver of Stroked Lightning 11.519 @ 119.26 mph
Builder and Driver of Blue Thunder
Weweld is offline
post #4 of 25 (permalink) Old 05-13-2007, 02:54 PM
dzljon's Avatar
cut off date between early and late is, march 1999, the badging changed also so if you are not sure of a build date if the Powerstroke badge is behind the head light it is ealry, if it is on the door it is a late, assuming the previous owner did not change anything. you can also look at the turbo they changed bewteen ealy and late.
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
post #5 of 25 (permalink) Old 05-13-2007, 06:56 PM
No it isn't, it's December 98.
gregrob is offline
post #6 of 25 (permalink) Old 05-13-2007, 07:00 PM
dzljon's Avatar
i will argue this be cause mine was born in march and i have gotten wrong parts, any time i order some thing they ask if it was made after march, so if it was dec, why would they ask this. even in 2003 they did not release the 6.0 till march, ford does this for some odd reason mid year changes happen in march. and most recently the 6.4 it was released in march.
dzljon is offline
post #7 of 25 (permalink) Old 05-13-2007, 07:19 PM
Powered By Ford
FordRacing200's Avatar
any pictures of your 97?
FordRacing200 is offline
post #8 of 25 (permalink) Old 05-13-2007, 07:23 PM Thread Starter
yeah it should be coming up on ebay here in just a little while i put it on there this morning but i guess becouse i live on the east coast and ebay is one the west coast you loss some time but it is a green reg cab long bed. lifted 4 in..
post #9 of 25 (permalink) Old 05-13-2007, 07:25 PM Thread Starter
so if the build date was 12/98 and the powerstoke is on the door, you think i got a early 99 or late 99 and whats the differeneces between the two like why is the later 99 so much better or thats what i have herd..
post #10 of 25 (permalink) Old 05-13-2007, 07:42 PM
dzljon's Avatar
badging dont mean much but there was a change to it, you would have to look at the other stuff to be sure, there were more than engine chages in 99 they chaged suspension components along with a few other items
the later version has better collector pipes(more commonly called up pipes) bends and different collecter that the tubo mounts to and the turbo pedistal and turbo are differnet, easier to remove on the later version but performance could easily be debated the after market does not have much for early 99 models, also on the later version the intake plenums were changed and also the inter cooler plumbing. all and all i would rather have the later version.
dzljon is offline
