fuel leak !!!help OBS - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by strokedout_07, this thread has received 10 replies and been viewed 1142 times.
post #1 of 11 (permalink) Old 05-19-2007, 05:44 AM Thread Starter
i have a 95 ford and on the left side under the engine is fuel leaking looks like its coming from the bowl or the thing behind the bowl or could it be from the lines what could it be whats prone to hapin ?????????????????
strokedout_07 is offline
post #2 of 11 (permalink) Old 05-19-2007, 08:18 AM
When was the last time you changed your fuel filter? Did it come with a square cut or triangular cut gasket for the lid? The NAPA filters come with a square cut and they will leak. The proper gasket is the triangular cut ones.
Get some brake clean and spray the entire area down really good so that it's clean and dry. Start the truck up and drive it for a bit if necessary and check for leaks. This way you can see where it the leak is comming from.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #3 of 11 (permalink) Old 05-19-2007, 04:39 PM Thread Starter
well there's a puddle of fuel behind the bowl? and i dont think i bought it at napa i think it's a wix filter not sure thoughit dripping from the left side down the block ....
post #4 of 11 (permalink) Old 05-19-2007, 06:14 PM
pontiacross's Avatar
could be one of the sensors on the left hand side of your fuel bowl I have seen several of them leak. The fuel pumps are also pritty bad about leaking.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #5 of 11 (permalink) Old 05-19-2007, 06:25 PM Thread Starter
really would this hurt the pump? it leaks a good puddle on the ground .. it just started last sunday out of the blue :FORD
post #6 of 11 (permalink) Old 05-19-2007, 06:49 PM
NAPA uses Wix filters so it's very possible you got the square cut seal. The fuel will leak down the bowl and fill the little recesses in the block and progressivly fill them toward the back until it leaks out the back of the block. If the fuel pump is going bad it's possible that it's leaking out the weep hole on the pump. Get it all cleaned up and it should be much more obvious where the leak is comming from.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
post #7 of 11 (permalink) Old 05-19-2007, 07:34 PM
circle5's Avatar
It also could be the drain bowl o-rings. 3 bucks on ebay
circle5 is offline
post #8 of 11 (permalink) Old 05-20-2007, 04:37 PM Thread Starter
well i looked today and behinde the bowl or the side is dry on the bowl and everything behind it is also dry
post #9 of 11 (permalink) Old 05-20-2007, 04:55 PM
FRANKEN STROKE
The fuel lines are bad to dry rot in our modles, also look closely at the bottom, rear, passenger side of your fuel filter, they have been known to crack there! Also do you park your truck frontend pointed up hill, or downhill this might cause you to look in the wrong place. Check your lift pump, were the lines from the heads go in the back and see if the big bolt is leaking!
GOOD LUCK!
96 F-250 4X4,DP Tunner, EZmod, up graded IDM, custom drive shafts, staight axle up grade, 5-speed,head studs, bps bypass, dual HPOP's, AFE Filter, aeromotive fuel system, tubes, springs, oringed, copper head gaskets, 5" stacks (all chrome), south-bend dd clutch, H2E big spinny thing, some hugh-jazz injectors, 3" body lift (had to fit the turbo in), homemade traction bars fromt and rear, blood sweat & lockers!!
Four different trucks had to die to make this one!!!!!!!!!!!Thats why we call him FRANKEN STROKE! Too much fuel, and not enough money
Sled pulling in NC,TENN,VA,and anywere else theyll let us!!!!!
P.S. Dont be afraid of the sawzall! It can fix anything!
[email protected]
DONATIONS EXCEPTED!!!!!!
Franken-stroke is offline
post #10 of 11 (permalink) Old 05-21-2007, 05:53 AM
I also had a leak and my whole top of my motor was full of fuel.My lines where dry and cracked but that wasn't the problem.On the drivers side of the fuel filter there is fuel part that has two bolts that hold it on and inside there is a oring and thats what was leaking.It would also be a good idea to change your little hoses while you got it apart.
snopro99 is offline
