Pro Comp 6" Lift Kit - Advice Please. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by AllOut0606, this thread has received 4 replies and been viewed 633 times.
post #1 of 5 (permalink) Old 05-26-2007, 03:46 PM Thread Starter
TDG Mafia Member # 70
Send a message via AIM to AllOut0606
Today i am going to look at a used 6" lift from an 03 7.3L excursion. What is the difficulty in this; i have to take it off of the excursion and put it on my f250. I am mechanically inclined, i'm sure i can do it. Anything i should remember or look for when i go to see his truck with the kit on it?
Any advice or input will be much appreciated. Thanks.
2000 F250 7.3L CC Lariat 4X4 SB;
Performance:TS Performance Tuner///K&N Intake///Custom 5" Straight Pipe///6.0 Intercooler///B&M Trans Cooler///Foil Delete///Zoodad///CCV.
Interior: Autometer Gauges: Pyro, Trans, and Boost///Alpine In-Dash DVD Player///Audiobahn Sound System///Cobra 29 CB.
Exterior: Pro Comp 4" Lift///36" Super Swampers///16" wheels///Dual Hadley Peterbilt Horns///Viair 380c Compressor///Two 3 gallon air tanks///20% Tint///Warn Standard Hubs.
-Marshall-
AllOut0606 is offline
post #2 of 5 (permalink) Old 05-26-2007, 04:35 PM
strokin now cummin later!
Orangepstroke's Avatar
to my knowledge there isnt much. ask him if he had to make his front drive shaft longer. thats all i know. i put a 10" superlift on dads truck. it was easy just a lot of heavy parts
Orangepstroke is offline
post #3 of 5 (permalink) Old 05-26-2007, 09:48 PM Thread Starter
did you put a longer drive shaft in your dads truck or have to make it longer?
-Marshall-
post #4 of 5 (permalink) Old 05-26-2007, 10:16 PM
yeah we to it to the machine shop and had 6 inches added to it
post #5 of 5 (permalink) Old 05-31-2007, 03:48 AM
I've got their 6" lift on my truck, no drive shafts needed, you may need to space the rear drive shaft if you have a carrier bearing. This will eliminate the shudder/vibration you may get on acceleration with the addition of this kit. . .also expect to see a pretty significant drop in mpg.
trick76cj5 is offline
