where do i put my oil pressure sensor? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SICKS-O, this thread has received 9 replies and been viewed 1526 times.
post #1 of 10 (permalink) Old 05-29-2007, 03:52 AM Thread Starter
Slow 6.0
im buying a oil pressure gauge, just wondering where the best spot is to put the sensor
2006 F350 XLT 4x4
SICKS-O is offline
post #2 of 10 (permalink) Old 05-29-2007, 05:54 AM
TDG Mafia Member #73
Is it for the HPOP???
mattymx is offline
post #3 of 10 (permalink) Old 05-29-2007, 05:55 AM Thread Starter
Slow 6.0
no, lube oil pressure
2006 F350 XLT 4x4
SICKS-O is offline
post #4 of 10 (permalink) Old 05-29-2007, 07:22 AM
You can put it in the oil filter adapter, there is an 1/8" pipe plug (hex head)just below the block heater cord. On the very back of the block, facing left there is another 1/8" pipe plug with a square drive end on it that is drilled into the main bearing lube galleries. Either of these places are good sources of lube oil pressure.
1040 WreckerMan is offline
post #5 of 10 (permalink) Old 05-29-2007, 01:10 PM
CSIPSD's Avatar
Here are a couple of shots, top of the HPOP res and the oil filter loc.
Name:	oil temp 2.JPG
ID:	10336   Click image for larger version
Name:	oil pressure gauge.JPG
CSIPSD is offline
post #6 of 10 (permalink) Old 05-29-2007, 02:44 PM Thread Starter
Slow 6.0
awesome, thanks guys
2006 F350 XLT 4x4
SICKS-O is offline
post #7 of 10 (permalink) Old 05-30-2007, 06:00 AM
Hotsauce2138
Send a message via AIM to HotSauce2138 Send a message via MSN to HotSauce2138
joe is that first pic for a oil temp?
SAM
Late 99 F-250 CC SWB Lariat 6 sp. 4x4 - the mods= Garrett GTP38R Turbo, DDP Stage 2 Single Shot Injectors. Shimmed Regulator, CCV Reroute and HX Hose from Dfuser, 4" turbo back straight pipe to GR 5" stack kit w/ 7"mitre cut stacks DPPPOWER.COM, AFE Stage 2 Intake w/ PG7, DP Tuner F5 Chip, 18K Mod Dfuser, SouthBend Clutch, Pro Pods quad a-pillar pod, Autometer Ultra-Lite Series Guages ( EGT, Boost 0-35, Trans Temp, Fuel Pressure and Engine oil temp.), Pro tech cab guard, WELD Sidewinders. Road Armor's!!! Custom Pro Tech toolbox/stack cover, , Sirius Sat. Radio, BD Exhaust Brake, 06 Towing Mirrors w/ LED blinkers and heated
:93C_peelo
My Gallery: http://fordtruckworld.tenmagazines.c...y.asp?id=18074
Singles Club Member #52
Can You Keep Up??
Because I'm trying to. lol
HotSauce2138 is offline
post #8 of 10 (permalink) Old 05-30-2007, 06:05 AM
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
I would think either place would work
POWER STROKE 99 is offline
post #9 of 10 (permalink) Old 05-30-2007, 05:37 PM
CSIPSD's Avatar
Yes, thats where I have my oil temp gauge. But any location will work.
CSIPSD is offline
post #10 of 10 (permalink) Old 05-31-2007, 01:12 AM
Hotsauce2138
joe by putting that there it is engine oil temp right?
SAM
:93C_peelo
Can You Keep Up??
