aux trans cooler 99 7.3 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by double-s-diesel, this thread has received 11 replies and been viewed 1147 times.
post #1 of 12 (permalink) Old 07-25-2007, 10:14 PM Thread Starter
rock removal technition
adding an extra cooler to a 99.
should I plumb before or after the stock cooler.
and which lines are which , feed and return.
Nick
double-s-diesel is offline
post #2 of 12 (permalink) Old 07-26-2007, 02:28 AM
4cstr
Plumb it after your stock cooler. Thats how I have mine plumbed in.
post #3 of 12 (permalink) Old 07-26-2007, 12:16 PM
6.0 powered
Anyone have a write up on how to do it on an 01. I looked around but couldnt find one
Dave is offline
post #4 of 12 (permalink) Old 07-26-2007, 03:27 PM
What about just swapping yours out for a 6.0 trans cooler? Anyone done this yet? I remember reading(not sure where) it fits the same mounting tabs, and uses WAY more tubes tool cool, no real test numbers though.
dweymer is offline
post #5 of 12 (permalink) Old 07-30-2007, 11:35 PM
I found it, diesel power magazine, August 07 page170. They say the 6o flows up to 186% more fluid and uses 25 rows as opposed to the 9 rows the 7.3 unit uses. Both use the same mounting locations.
dweymer is offline
post #6 of 12 (permalink) Old 07-31-2007, 01:15 AM
6.0 powered
Thats a great idea if you have 450 bucks laying around for a 6.0 tranny cooler
Dave is offline
post #7 of 12 (permalink) Old 07-31-2007, 01:35 AM
d&mn, they that much?
Nevermind that then!
dweymer is offline
post #8 of 12 (permalink) Old 07-31-2007, 01:48 AM
minor rumbler
My tranny guy say he always shys away from transcoolers in the radiator anyways seeing as if any fluid transfers from the radiator your screwed. He is a major proponent of stacked plate transcoolers over tube and fin aswell !!!
NORCAL-NOODLER is offline
post #9 of 12 (permalink) Old 07-31-2007, 01:55 AM
TDG Mafia Member # 70
Send a message via AIM to AllOut0606
i bought an 89 dollar B&M transcooler from jegs. i love it, i plumbed it after the stocker, and mounted it right behind the grill. looks good painted green too.
i never see trans temps over 140 degrees. even when towing, never went over that temp.
2000 F250 7.3L CC Lariat 4X4 SB;
Performance:TS Performance Tuner///K&N Intake///Custom 5" Straight Pipe///6.0 Intercooler///B&M Trans Cooler///Foil Delete///Zoodad///CCV.
Interior: Autometer Gauges: Pyro, Trans, and Boost///Alpine In-Dash DVD Player///Audiobahn Sound System///Cobra 29 CB.
Exterior: Pro Comp 4" Lift///36" Super Swampers///16" wheels///Dual Hadley Peterbilt Horns///Viair 380c Compressor///Two 3 gallon air tanks///20% Tint///Warn Standard Hubs.
-Marshall-
AllOut0606 is offline
post #10 of 12 (permalink) Old 07-31-2007, 02:04 AM
Yeah, but which hose on the factory cooler is the return line?
USAFdieselman is offline
