7.3 question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dustin 08, this thread has received 6 replies and been viewed 707 times.
post #1 of 7 (permalink) Old 07-29-2007, 07:35 AM Thread Starter
7.3 question
jus wonder what the average hp and torque ratings of a 7.3 powerstroke was and why Ford went from that to a 6.0 ive always been around cummins and i was just curious
dustin 08 is offline
post #2 of 7 (permalink) Old 07-29-2007, 07:52 AM
1996 StrokerKid's Avatar
went to the 6.0 cuz of emmisions and that how navistar designed it. correct me if im wrong
1996 F-350 LB CC 4 in. lift 35 in. BFG AT's Go Rhino Grill Gaurd, Stancor GPR.
"Id rather be stroked than rammed!"
1996 StrokerKid is offline
post #3 of 7 (permalink) Old 07-29-2007, 12:23 PM
BillsFan's Avatar
Don't know how accurate these are but I found them a few places on the web as stock 2002 7.3 numbers.
HP
275 @ 2800 (manual)
250 @ 2600 (automatic)
Torque (lb.-ft.) @ rpm
520 @ 1600 (manual)
505 @ 1600 (automatic)
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #4 of 7 (permalink) Old 07-29-2007, 12:42 PM
97F-3504X4PSD
Andy King's Avatar
VC sticker on the 97 says 225HP @3000 RPM. Torque is around 425Ft/lbs
97, F-350, 7.3 PSD, OBS, 4X4, Reg. Cab, SRW, 4.10 gears w/ Locking rear, 235-85/R16s, Shimmed FPR, Zoo Dad, DIY intake, Turbo friendly Cat., Transgo Tugger Kit(RacerX).
Next(3"-3.5"-4" downpipe & 4" Exhaust)
"You may take a bullet, but you will never take one of my guns"
Andy King is offline
post #5 of 7 (permalink) Old 07-29-2007, 05:38 PM
tjl
tjl's Avatar
valve cover on 96 says 215hp and 400ft/lbs
Tim
'96 f350 cc dually, 5 speed w/ short throw shifter, stage 1 injectors, '03 sd intercooler, d66 turbo, DP Tuner F5 chip (stock, high idle, tow, econo, extreme) modified IDM, CCV mod, gutted EBPV
343 hp
670 tq
Dually Club #20
B.O.M.B. Squad #7
tjl is offline
post #6 of 7 (permalink) Old 07-29-2007, 07:08 PM
The '94-'97s usuall make about 170ish at the wheels and the SDs make right at 200 at the wheels. They went to the 6.0L because it was the next step in design. It's rated at more power and is supposed to have less emissions as well. Now they went to a 6.4 twin turbo.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #7 of 7 (permalink) Old 07-29-2007, 07:22 PM
4cstr
Those numbers you see on the valve cover are flywheel HP...not rearwheel. Flywheel numbers will always be bigger since it won't take into account driveline parasitic loss of HP getting to the rears.
The biggest reason for going to the 6L was meeting emission requirements.
