Oil in Coolant???? - Page 2 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fords4life, this thread has received 14 replies and been viewed 32270 times.
post #11 of 15 (permalink) Old 07-30-2007, 08:29 PM Thread Starter
Would there be any external signs of the oil cooler being the culprit besides oil in the coolant, or is it all internal?
fords4life is offline
post #12 of 15 (permalink) Old 07-30-2007, 11:25 PM
it could be leaking oil or coolant externally but most likely it's just leaking internally.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #13 of 15 (permalink) Old 07-31-2007, 02:08 PM
GTS I have seen inj cups leak at the bottom edge leaking coolant into the cylinder when shut off allowing coolant to seep past rings into pan .. this of course is usually joined by an overheat issue from compression getting into the coolant when running.
as for the cooler leakiing externally they can leak oil externally from the orings at the heads or leak oil or coolant from mounting gaskets if it is blown internally or the oring is bad coolant wont leak externally it will just let oil into the cooling system
Photos of The Beast
DOC
Docluv2577 is offline
post #14 of 15 (permalink) Old 07-31-2007, 06:13 PM
Correct on all accounts. I said you can't get oil in the coolant from the injector cups. You can get coolant in the oil as you described though.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
post #15 of 15 (permalink) Old 07-31-2007, 11:41 PM
If you are careful you can pull the cooler assembly out of the truck to the rear (towards the cab) without pull the motor mounts. It's a bit of a tight fit, but it can be done.
1040 WreckerMan is offline
