7.3 no start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_Prodiesel, this thread has received 7 replies and been viewed 635 times.
post #1 of 8 (permalink) Old 08-01-2007, 01:03 AM Thread Starter
7.3 no start
working on a 95 7.3 auto , was running real rough when drove into shop , found 1 bad injector , replaced and resealed the rest , started and ran well , after a while shut off and let set for an hour , extended crank but started , let set overnite , no start , cam sensor new , hpop res low , refilled several times trying to start after each time , no start , fuel pres. 50# , no codes , fuses good , relays good , new batteries and good cranking speed , thanks for any ideas
imported_Prodiesel is offline
post #2 of 8 (permalink) Old 08-01-2007, 03:14 PM Thread Starter
Filled the res. and let it set overnite and it was still full this am. just cranks over and no smoke.
post #3 of 8 (permalink) Old 08-01-2007, 03:50 PM
TDG Mafia - Booze Runner
Snowaholic's Avatar
pull the edge, and try...are you sure the UVC Harness is fully clipped together
2007 Dodge 3500 MegaCab Laramie CTD 4x4 Patroit Blue Just a bunch of Go fast parts and programing
Snowaholic is offline
post #4 of 8 (permalink) Old 08-01-2007, 05:22 PM Thread Starter
This truck has a Powerbreaker chip , all the connections are good at the valve covers , pulled the iICP sensor and turned over there was oil flow , going to get a guage and check pressure next , any other ideas ??
post #5 of 8 (permalink) Old 08-01-2007, 05:53 PM
Mod Friendly Title
Zaairman's Avatar
You getting a wait to start light?
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #6 of 8 (permalink) Old 08-01-2007, 05:59 PM Thread Starter
Yes it does
post #7 of 8 (permalink) Old 08-01-2007, 08:45 PM Thread Starter
Checked the oil pressure at the head and it would only get to about 400#
post #8 of 8 (permalink) Old 08-13-2007, 02:32 PM Thread Starter
Replaced the HPOP , runs good now but has extended crank time , will start rite away after shutting off but let it set for 5 min. and it takes awhile , the fuel pressure runs at 55# when shut off it slowly drops down to 20# , cleaned the screen (was almost plugged) . should the pressure drop like this ??
