7 pin connector ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by youngPSD, this thread has received 8 replies and been viewed 572 times.
post #1 of 9 (permalink) Old 08-06-2007, 01:19 AM Thread Starter
7 pin connector ?
i pluged my trailer into my truck and for some reason the brake lites and turn signals dont work.. the park lights work and the trailer brakes work had a guy look at it and hes not famillar with superdutys he said he would need a wiring diagram but if you guys would now of any relay that i could check that would be nice..The one 20 amp fuse was not blow either...
2002 f-250 supercab shortbed on 305/70/16 BFG A/T with 3.73 gear MODS Pyro,Boost,TransTemp Guages 4" MBRP Turbo back exhaust
youngPSD is offline
post #2 of 9 (permalink) Old 08-06-2007, 03:15 AM
Slow 6.0
the fuses for that stuff are in the black fuse box under the hood on the drivers side
2006 F350 XLT 4x4
SICKS-O is offline
post #3 of 9 (permalink) Old 08-06-2007, 03:41 AM
Dieselis' Maximus
driximus's Avatar
Easiest thing to do would be to just get a meter or a pen light. start following either from the fuse boxes or from the lights back to the fuse boxes. If you pick up one of those 20 dollar chiltons they have the schematics in them.
"Why in hell can't the Army do it if
the Marines can. They are the same
kind of men; why can't they be like
Marines."
Gen. John J "Black Jack" Pershing, USA; 12 February
1918
driximus is offline
post #4 of 9 (permalink) Old 08-06-2007, 04:06 AM
Here's a dumb but easy fix. Sometimes the spring blades on the connector get tweaked and not make contact. If you take a flat screw driver and bend them towards the center of the connector, they will make contact again and work right.
03' 6.0 Excursion 4x4 Eddie Bauer.
99' F350 4x4 XLT CC/LB.
skav is offline
post #5 of 9 (permalink) Old 08-06-2007, 05:35 AM
Slow 6.0
check the fuses first, its FREE & easy
2006 F350 XLT 4x4
SICKS-O is offline
post #6 of 9 (permalink) Old 08-06-2007, 12:08 PM
6.0 powered
Its just a fuse it happens to my work truck all the time
Dave is offline
post #7 of 9 (permalink) Old 08-06-2007, 08:50 PM
Are the fuses seperate for left and right? My left wont work, but right is fine. Gotta take a test light to the truck to make sure it isn't the trailer.
dweymer is offline
post #8 of 9 (permalink) Old 08-06-2007, 09:07 PM
Dieselis' Maximus
driximus's Avatar
this might also sound silly. Make sure your ground for your trailer lights is connected to the trailer and the trucks bumper or grounded to the truck.
Marines."
1918
driximus is offline
post #9 of 9 (permalink) Old 08-06-2007, 10:46 PM
Slow 6.0
yup there are seperate fuses for everything
2006 F350 XLT 4x4
SICKS-O is offline
