500 hp + on a OBS powerstroke - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 7.3stroker, this thread has received 20 replies and been viewed 11457 times.
post #1 of 21 (permalink) Old 08-08-2007, 07:06 PM Thread Starter
wat all is involve and how much does it cost to get over 500 ponies in an OBS
97 f 250 xlt 4 inch lift, 36/15.50 tires, hypermax kit with sledghammer turbo, swamps 355mm injectors, compitition fuel system,bdp stealth pumps oil system, head studs, custom 4 inch exhaust, edge evo and ez stack
7.3stroker is offline
post #2 of 21 (permalink) Old 08-08-2007, 07:38 PM
Slow 6.0
umm with what u have listed in your sig you should already be there. maybe whats holding you back is that EDGE stuff your running, a setup like that needs custom tuning, atleast an over the phone tune from one of the popular 7.3L program vendors.
2006 F350 XLT 4x4
SICKS-O is offline
post #3 of 21 (permalink) Old 08-08-2007, 07:56 PM Thread Starter
i have over 500 by alot :Thumbup: my buddy wants about 5 for the cheapest and easyiest way to get it
post #4 of 21 (permalink) Old 08-08-2007, 08:19 PM
soot junkie
It looks like you have spent the money to get there. So you can tell your friend, from first hand experience that it is not cheap at all to get 500 hp.
01 F350 CC Dually, DP tuner, fuel system w/Aeromotive pump, 360cc Stage III Hybrids, Stealth Big Oil, H2 Hybrid, Head Studs, Hypermax rods, balanced rotating assembly, Comp Cams valve springs and push rods, ATS trans fixed by BTS, Best 1/4 [email protected] best 1/8 [email protected]
2000 F250 6sp, Dp Tuner
Early 99 F350 2wd daily driver Dp Tuner
smokin dually is offline
post #5 of 21 (permalink) Old 08-08-2007, 08:30 PM
Luke made 550 on a set of Hybrids, stock HPOP and a Modded H2E from Beans Diesel and Tony's tunes. You would need a fuel system to support the injectors also.
From the sounds of it the bottom end was replaced soon after due to mechanical failures :shrug:
BTW, I thought you were asking a while back how much power your setup would make due to you not having access to a dyno. So how do you know you are over 500? :
J/K
Eric
Dually Club Member #53
racehauler is offline
post #6 of 21 (permalink) Old 08-08-2007, 08:33 PM
Im surprised your over 500 with the Edge, what did it dyno out at?
dhooks is offline
post #7 of 21 (permalink) Old 08-08-2007, 08:39 PM Thread Starter
i havent dynoed it but i no a guy that has about 450 in a 02 powerstroke and i can blow away from him like its nuttin so im jus guessin
post #8 of 21 (permalink) Old 08-08-2007, 10:34 PM
Slow 6.0
did he get that number from his butt dyno?
2006 F350 XLT 4x4
SICKS-O is offline
post #9 of 21 (permalink) Old 08-09-2007, 01:41 AM
Retread
shawnrans's Avatar
Is that the new "Analmometer" :roflmao:
"The Diesel Garage Rocks
shawnrans is offline
post #10 of 21 (permalink) Old 08-09-2007, 02:32 AM
Where is there a dyno in New York around Albany that can handle a diesel. Just wondering if anyone has a clue.
Andy is offline
