7.3l Mpg - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by oldforge1, this thread has received 18 replies and been viewed 2300 times.
post #1 of 19 (permalink) Old 08-12-2007, 11:51 PM Thread Starter
7.3l Mpg
I am new here, But I have driven many fords, I am looking at getting a 2003 7.3L auto with 78k on it. I know many guys say they get upward of 24-26mpg but I am wondering what real people get with theirs? what should I expect and what can I do to get better mileage out of it?
oldforge1 is offline
post #2 of 19 (permalink) Old 08-13-2007, 12:17 AM
I be Architect'n
Max of 18-20 on highway w/o too many mod's. You can get, maybe, 24 if you have a 6-speed 2WD and do alot of aero. work. 13-15 around town is typical.
2K3 EXCURSION 7.3L 4x4 EDDIE BAUER 107K miles as of 06-13-07
AFE Stage II / 4" MBRP exhaust / DP-Tuner F5 (Stock, 60hp Tow, 80hp Econo, 120hp race & High Idle) / Quadzilla Commander/ATS Housing
Running homebrewed BioDiesel and custom SVO kit for 70k miles.:Thumbup:
Misc. Mods: ZooDad/By-Pass Oil Filter/203* T-Stat/Coolant Filter/HPX/CCV Reroute/Tranny Filter/Foil Delete/Stereo Stuff/ITP Reg Return/Non-EBPV Pedistal and Exhaust Housing/Adjustable Waste Gate Controller/
"If you love your motorcycle, set it free. If it comes back to you it was probably a high-side."
I'LL TRY TO KEEP UP, BUT THE EXCURSION IS A BIG GIRL AND BIG GIRLS DON'T LIKE TO MOVE FAST.
6_Myles is offline
post #3 of 19 (permalink) Old 08-13-2007, 12:23 AM
24-26 can be done, but it takes a lot of work and a lot of discipline. It is my no means the norm. I average 15 mixed driving...
early '99 converted to late '99 F-350 dually, 4x4, 4 door, long bed, 6 speed. Midwest transmissions 05+ zf-6 transmission with their short throw shifter and SB clutch. Rosewood 180cc with 80% nozzles, Termy modded 17* HPOP, International bellowed up pipes, fs-2500, DP Tunes. A few other things here and there...
dually club member.. Why replace 5 tires when you can replace seven? I like my training wheels...
calebgriffin31 is offline
post #4 of 19 (permalink) Old 08-13-2007, 12:48 AM
bpogue's Avatar
I have a 2001 crewcab flatbed with a 6 speed manual. I get 12-14 most of the time. Most trailers dcn't make a difference. My trips are mostly 20-40 milee each way and 60 mph max.
bpogue is offline
post #5 of 19 (permalink) Old 08-13-2007, 01:09 AM
Slow 6.0
i average 15 usually, i also drive like an ***. but i wouldnt expect 24-26 thats really high.
2006 F350 XLT 4x4
SICKS-O is offline
post #6 of 19 (permalink) Old 08-13-2007, 02:09 AM
I get any where from 15-18 mpg on each tank. I have seen people who get into the mid 20s by using an economy tune with mods like new air intake exhaust and other mods like propane or water methanol injection. Also if you keep your rpms below 2000 at all times you can get from 18-20 mpg and you are not wearing out the engine as fastly. You can also reduce excess weight and put on a bed cover.
imported_Stroker01 is offline
post #7 of 19 (permalink) Old 08-13-2007, 03:49 AM
pontiacross's Avatar
My brother just got a 01 2wd extended cab 6 speed that is bone stock and is getting around 21mpg with it. he is getting ready to do some mods to inprove on that such as a chip, exaust, intake, and 3.08 gears.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #8 of 19 (permalink) Old 08-13-2007, 05:06 AM
BillsFan's Avatar
I average between 16-17 mpg per tank but I usually have my foot in it more than I should.
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #9 of 19 (permalink) Old 08-13-2007, 05:21 AM
TDG Mafia Member # 37
01blkf250's Avatar
When I was running Jody's (DP Tuner) 80 hp econo tune, unloaded on the highway keeping it below 2000 rpm I could get 24 mpg. The norm though was usually between 21 - 22 mpg. I could also get 18.5-19 aound town driving. I do not get those numbers with the 60 hp tow or the 120 hp fun programs though. I truly think Jody's 80 hp econo tune is the best tune I have run, it was fast, but economical, and while not a towing program it seemed to work better for my loads than the 60 hp tow program has done for me. I also got a best of 17.7 pulling my 5th wheel on the highway with that tune, but I can get 15.5 -16 with the 120hp tune pulling the same 5th wheel. When I get my injectors and big oil, and I 'll have a need for changing my F5 chip programs then I'll get the 80 hp econo tune back. Gene :mafia
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
post #10 of 19 (permalink) Old 08-13-2007, 06:19 AM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
i get any were from 13-16 depnding on how i drive
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
