5'' exhaust on a OBS - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_7.3FordPower, this thread has received 8 replies and been viewed 1750 times.
post #1 of 9 (permalink) Old 08-13-2007, 05:03 PM Thread Starter
like it says who put a 5'' straight pipe on their OBS truck. did you have a local shop do it or buy a kit from somewhere. Also how much did it set you back. any help would be good.
imported_7.3FordPower is offline
post #2 of 9 (permalink) Old 08-13-2007, 05:12 PM
tjl
tjl's Avatar
I've never seen a 5" straight pipe on an OBS but I had a 4" straight pipe on mine before I put my stacks on. I just had a local muffler shop do it.
Tim
'96 f350 cc dually, 5 speed w/ short throw shifter, stage 1 injectors, '03 sd intercooler, d66 turbo, DP Tuner F5 chip (stock, high idle, tow, econo, extreme) modified IDM, CCV mod, gutted EBPV
343 hp
670 tq
Dually Club #20
B.O.M.B. Squad #7
tjl is offline
post #3 of 9 (permalink) Old 08-13-2007, 07:46 PM
Supporting Vendor
I put mine in from a kit from Tymar. Can't remember how much it cost, but it was pretty reasonable. Mine uses a 5" free-flowing muffler. It took a little bit of fabrication, since my downpipe exits at 4" dia. Dale at Tymar went ahead and welded on a 4" to 5" adapter for me on the downpipe. It's pretty snug where it passes over the axle and past the spare, but it does fit.
Regards,
Michael Pliska
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 271k miles
10 ISSPRO Prototype Performax™ gauges in Pillar & Overhead pods & sitting on dash, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Baby Swamps, Swamps tunes, Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
1998 S&S 9.5' slide-in camper
32' enclosed tag trailer with 2 drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
2000 VW Jetta TDI - Kerma tune, Der Chimera Stage II Clutch
NRA member and certified firearms instructor, GOA Life member, IDPA member
Michael is offline
post #4 of 9 (permalink) Old 08-14-2007, 01:16 AM Thread Starter
anyone else seen one before?
post #5 of 9 (permalink) Old 08-14-2007, 03:01 AM
RPM Outlet sells a 5" setup. I dont know anything about it, just happened to see it on the website.
racejunkie93 is offline
post #6 of 9 (permalink) Old 08-14-2007, 03:30 AM
TDG Mafia Member # 70
Send a message via AIM to AllOut0606
i went to a Keller Truck Parts today to buy pieces to make my 5" dual exhaust, and that is the way to go. much cheaper then a kit, just as easy to install if you have a little mechanical skills and common sense.
http://www.kellertruck.com/
2000 F250 7.3L CC Lariat 4X4 SB;
Performance:TS Performance Tuner///K&N Intake///Custom 5" Straight Pipe///6.0 Intercooler///B&M Trans Cooler///Foil Delete///Zoodad///CCV.
Interior: Autometer Gauges: Pyro, Trans, and Boost///Alpine In-Dash DVD Player///Audiobahn Sound System///Cobra 29 CB.
Exterior: Pro Comp 4" Lift///36" Super Swampers///16" wheels///Dual Hadley Peterbilt Horns///Viair 380c Compressor///Two 3 gallon air tanks///20% Tint///Warn Standard Hubs.
-Marshall-
AllOut0606 is offline
post #7 of 9 (permalink) Old 08-14-2007, 03:35 AM
Yeah, pre-rear wheel is sorta easy, its just gettin up over the axle thats the trouble. Just go somewhere they sell 4" and up exhaust (truck shop) and you can find pretty much all the pieces you need.
ckbed is offline
post #8 of 9 (permalink) Old 08-14-2007, 06:32 AM
exhaust over the axel but i also have a 4inch lift too so i have no bends over the axel. but reall easy just get u 2-45deg pipe and 2-90deg pipe and clamp them together real easy i have done this to a d-max cummins and a ford psd and works great
strokedout_07 is offline
post #9 of 9 (permalink) Old 08-15-2007, 12:08 AM Thread Starter
Alright I will look into these things thanks for the help
