97 turbo problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Slobrdog, this thread has received 7 replies and been viewed 841 times.
post #1 of 8 (permalink) Old 08-15-2007, 07:31 AM Thread Starter
Cool 97 turbo problem
97 Powerstroke stock turbo and injectors my local garage tells me the 97 does not have a waste gate in it so what is the butterfly gate on the discharge side of the turbo? and what will happen if i take it out it seems to be sticking?
Slobrdog is offline
post #2 of 8 (permalink) Old 08-15-2007, 08:05 AM
It's an exhaust back pressure valve. It's used to help keep the engine warm and up to operating temps when it's very cool out. You can take it out with no problem unless it's sub freezing temps there it might run cold and take a long time to warm up when cold. It's relativly common for them to stick.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #3 of 8 (permalink) Old 08-15-2007, 09:20 PM Thread Starter
Thanks powerstroke winter gets a bit cold here in Utah is there an aftermarket replacement for this or a way to fix it??
Slobrdog is offline
post #4 of 8 (permalink) Old 08-16-2007, 06:14 PM
You can replace it. Or I guess you might be able to clean it and reinstall it. It gets carbon build up around the butterfly and shaft which causes it to stick.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
post #5 of 8 (permalink) Old 08-18-2007, 06:06 PM
Try putting a large spring on the lever to help it open. I did that over 2 years ago after the dealer was unable to solve my problem. All they could suggest was replacement, so I figured why not? It still works when it's cold and pops right open when warm. Best $2.00 I ever spent!
tronerdog is offline
post #6 of 8 (permalink) Old 08-19-2007, 06:49 AM
Try the suggestions, plus clean out the tube under the EBP sensor on the front of the engine. The tube clogging causes the sticky EBPV many times.
RacerX is offline
post #7 of 8 (permalink) Old 08-19-2007, 07:42 PM
whst part of utah im from slc
19stroker96 is offline
post #8 of 8 (permalink) Old 08-25-2007, 03:15 PM Thread Starter
IM in Tooele Stroker Nice to meet ya.
Slobrdog is offline
