2000 Rpm? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Andy King, this thread has received 13 replies and been viewed 1024 times.
post #1 of 14 (permalink) Old 08-19-2007, 01:22 PM Thread Starter
97F-3504X4PSD
Andy King's Avatar
2000 Rpm?
I keep reading the threads concerning 7.3l MPG. Someone always mentions staying under 2000 RPM. Why? What is the engine doing different above 2000? Just wondering.:thanks:
97, F-350, 7.3 PSD, OBS, 4X4, Reg. Cab, SRW, 4.10 gears w/ Locking rear, 235-85/R16s, Shimmed FPR, Zoo Dad, DIY intake, Turbo friendly Cat., Transgo Tugger Kit(RacerX).
Next(3"-3.5"-4" downpipe & 4" Exhaust)
"You may take a bullet, but you will never take one of my guns"
Andy King is offline
post #2 of 14 (permalink) Old 08-19-2007, 01:52 PM
It's fueling more over 2K RPM's.
Every single engine gas or diesel has a specific RPM range that is optimal for fuel mileage.
Pocket is offline
post #3 of 14 (permalink) Old 08-19-2007, 05:01 PM
Diesel Enthusiast
Torque curve would be my guess, but I don't exactly have a degree in this or anything.
2002 F250 Extended cab XLT 4X4 long bed.
Intake, muffler delete, DP-Tuner
1997 F250 Regular cab 5 speed 4x4.
3in Downpipe, Stage 1 sticks, solid flywheel conversion, 6 position chip. Work truck.
5gear is offline
post #4 of 14 (permalink) Old 08-19-2007, 06:48 PM
TDG Mafia Member # 70
Send a message via AIM to AllOut0606
how fast are you all going at 2000 rpms? i am going 65 mph.
the reason i ask, is because i dont know what rear is in my truck. its not on the door frame nor the metal labels on the diff cover.
2000 F250 7.3L CC Lariat 4X4 SB;
Performance:TS Performance Tuner///K&N Intake///Custom 5" Straight Pipe///6.0 Intercooler///B&M Trans Cooler///Foil Delete///Zoodad///CCV.
Interior: Autometer Gauges: Pyro, Trans, and Boost///Alpine In-Dash DVD Player///Audiobahn Sound System///Cobra 29 CB.
Exterior: Pro Comp 4" Lift///36" Super Swampers///16" wheels///Dual Hadley Peterbilt Horns///Viair 380c Compressor///Two 3 gallon air tanks///20% Tint///Warn Standard Hubs.
-Marshall-
AllOut0606 is offline
post #5 of 14 (permalink) Old 08-19-2007, 09:51 PM
Allout0606 you have 3.73 ratio at that speed.
Josh
2000 F350 PSD CC 4X4 AT LWB 3.73s 173,000AFE STAGE I, TN.BB, EIS 200CC HYBRIDS F5 DP TUNER 4" TURBO BACK, AEROTURBINE 4040XL, 5" STACKS, ISSPRO GAUGES,PRE AND POST TURBO PYRO, SCANGAUGE.
ELKHUNTR is offline
post #6 of 14 (permalink) Old 08-19-2007, 10:02 PM
Hotsauce2138
Send a message via AIM to HotSauce2138 Send a message via MSN to HotSauce2138
i go 70mph @ 2000rpm
SAM
Late 99 F-250 CC SWB Lariat 6 sp. 4x4 - the mods= Garrett GTP38R Turbo, DDP Stage 2 Single Shot Injectors. Shimmed Regulator, CCV Reroute and HX Hose from Dfuser, 4" turbo back straight pipe to GR 5" stack kit w/ 7"mitre cut stacks DPPPOWER.COM, AFE Stage 2 Intake w/ PG7, DP Tuner F5 Chip, 18K Mod Dfuser, SouthBend Clutch, Pro Pods quad a-pillar pod, Autometer Ultra-Lite Series Guages ( EGT, Boost 0-35, Trans Temp, Fuel Pressure and Engine oil temp.), Pro tech cab guard, WELD Sidewinders. Road Armor's!!! Custom Pro Tech toolbox/stack cover, , Sirius Sat. Radio, BD Exhaust Brake, 06 Towing Mirrors w/ LED blinkers and heated
:93C_peelo
My Gallery: http://fordtruckworld.tenmagazines.c...y.asp?id=18074
Singles Club Member #52
Can You Keep Up??
Because I'm trying to. lol
HotSauce2138 is offline
post #7 of 14 (permalink) Old 08-19-2007, 10:14 PM
Riding solow on the Hog
Sleeperstroke's Avatar
Ill second that.
"MOby" The big white bio-burning 03 7.3 4x4. 6637, straight piped stock exhaust, and a new "secret" blend of Haul asBLEEPsing mods and upgrades. Suffice to say, its still not the fastest, but its quick enough to worry lots!
Sleeperstroke is offline
post #8 of 14 (permalink) Old 08-19-2007, 10:32 PM
TDG Mafia Member # 37
01blkf250's Avatar
I'll make that a 3rd. At 2000 rpm I am running 70 mph which is plenty fast when pullin my 5'er and it is where I get the best fuel economy on the highway. If I go over 2000 rpm to say around 2200 rom I'll lose about 2mpg in economy. Gene :mafia
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
post #9 of 14 (permalink) Old 08-19-2007, 10:54 PM
BlownGreenGP's Avatar
I run 65 @ 2000 rpm also (3.73). I try to keep it around that speed, but it's pretty difficult sometimes in MI, everybody wizzes by like you're standing still. Everybody running 70 @ 2000 has 3.55 gears. Kinda wish I had that ratio, but I could always swap them later.
SOLD2004 Dodge 3500-Quadzilla XZ2, 6" Black Mitre Stacks, PPE, DTT Trans
SOLD Early '99 F-250 XLT, 4x4, 6-speed
Diesel Innovations chip: stock, 50, 75, 110hp, 4" lift, Eagle 140 Black 18x10's w/ 35x12.5 Nitto Mud Grapplers, 4" turbo back to dual 5" Aussie stacks
SOLD2000 Grand Prix GTP Sedan
12.83 @ 108.68 mph on street tires
BlownGreenGP is offline
post #10 of 14 (permalink) Old 08-20-2007, 12:32 AM
Hotsauce2138
well what if we got bigger tires and a leveling kit doesnt that have something to do with higher speeds @ lower rpms?
SAM
:93C_peelo
Can You Keep Up??
