Idle Jumping up and down - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Whisperinghorse, this thread has received 5 replies and been viewed 712 times.
post #1 of 6 (permalink) Old 08-20-2007, 10:46 PM Thread Starter
At start mostly when it's warm I shut off and come back and start it the idle jumps up and down! So I was told that the CPS was going and to replace it! I did and right after I installed it did the same thing so I have a spare for when it does. So with the Idle jumps up and down at start what could be the prob?
Whisperinghorse is offline
post #2 of 6 (permalink) Old 08-20-2007, 10:56 PM
Most times the condition of the idle jumping up then down is called "the romps", just FYI.
When I asked about the romps on my PSD I was told that the IPR might be to blame, old or poor oil, oil too thick (not an issue this time of year), etc. I never really found anyting I could put my finger on but they went away. Sorry, not much help!
FireHunter is offline
post #3 of 6 (permalink) Old 08-21-2007, 12:39 AM
CSIPSD's Avatar
When it does it, just blip the throttle and it will settle down!
CSIPSD is offline
post #4 of 6 (permalink) Old 08-21-2007, 04:08 AM
Sounds like the IPR o-rings are going bad. On a side not I like my rompy idle in the extreme program. I had a mullet wearing fellow ask me what cam I had in my motor.
blindviper is offline
post #5 of 6 (permalink) Old 08-21-2007, 06:01 PM Thread Starter
When it does it, I can hit the pedal and it will settle down and if I don't it romps about three or four times and then settles down..
post #6 of 6 (permalink) Old 08-21-2007, 08:54 PM
Some just seem to do that. High ICP seems to cause it sometimes but I'm not sure that's your problem. If you get a chip with a different PCM code it may or may not go away. My friend's truck does it really bad when he first fires it up. He's running a TEE5 chip. Not sure how much it's related though.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
