torque converter - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 7.3stroker, this thread has received 6 replies and been viewed 845 times.
post #1 of 7 (permalink) Old 09-13-2007, 05:51 PM Thread Starter
torque converter
is there a way to drain the factory torque coneverter and if so does it simple refill when you fill the trans back up
97 f 250 xlt 4 inch lift, 36/15.50 tires, hypermax kit with sledghammer turbo, swamps 355mm injectors, compitition fuel system,bdp stealth pumps oil system, head studs, custom 4 inch exhaust, edge evo and ez stack
7.3stroker is offline
post #2 of 7 (permalink) Old 09-14-2007, 05:39 PM
You have to take the inspection cover off the trans and turn the flywheel with a prybar until the TC's drain plug shows. It will refill when ou load the trans with fluid.
NJStroker is offline
post #3 of 7 (permalink) Old 09-14-2007, 06:02 PM
Diesel Dave 04's Avatar
If It has a Drain you can do it that way, just fill it with 15QT before you start it Then add 1-3 more by checking it.
If it dont have a drain, like the newer ones We put the amount in that you drain out +4 Qt. then remove the rear line start the truck and fill a milk jug. do that 3 times and nice clean red fluid will show up and you are done.
08 F-350 crew cab Lariat 4X4 Dually auto 4:10 gears.
rideing on Hankook Dyna pro AT's
Diesel Dave 04 is offline
post #4 of 7 (permalink) Old 09-14-2007, 06:25 PM Thread Starter
so is all i have to do is add 15 qts to my trans start it up and it fills the converter back up
post #5 of 7 (permalink) Old 09-14-2007, 07:03 PM
yes it will pump the converter full all by its self, That is only if you drain the converter. If you dont drain it then you will only get about 8 qts out.
post #6 of 7 (permalink) Old 09-16-2007, 10:35 AM
I prefer to put 7 to 8 in. Than start the engine, run 15 second, shut down. Then add the rest.
RacerX is offline
post #7 of 7 (permalink) Old 09-16-2007, 05:34 PM
I wouldn't add all 15 qts at once with the engine shut off. I second RacersX's method. Put in 8-10qts start the truck, then add more fluid until full.
1040 WreckerMan is offline
