Hard start after cold night? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Beer Mod, this thread has received 17 replies and been viewed 2039 times.
post #1 of 18 (permalink) Old 10-14-2007, 12:37 AM Thread Starter
JUCK FEEP
Beer Mod's Avatar
I have a 02 7.3PSD that I use for work in Nor Cal. The truck starts fine at 2,000ft after a 20-30* night, BUT when I'm above 4,000ft it dosen't want to start for the first time of the day. I dont know why the higher elevation would have much to do with it, but it's the only thing that changes.
Any thoughts?
Singles Club #80
Ridin' High #32
02 F-350 7.3PSD CC Lariat Off RD PKG 8" lift 38x15.50 MT MTZ's 4.10 R&P Edge juice W/Attitude and Evolution 12K HID's 4" intake 4" strait pipe F450 HD Trans 5 Star Converter w/lock Tugger 2 and more....
99.5 Audi A4 1.8T Quattro Sport pkg 5spd GT2871R FMIC MBC 22psi 3" intake 19x8.5's JL Audio system and more.....
07 Rock Crawler Fuel injected 350 sm465 Dual Toyota cases Rockwells Billstein Coilovers PSC Hydro Ouverson brakes 44x18.50 TSL's 230:1 Crawl Ratio
My Buggy Videos
http://www.youtube.com/user/notquite.../1/WiawMf_296A
http://www.youtube.com/user/notquite...14/1ER50syjDco
http://www.youtube.com/user/notquite.../2/k4qSNjUd27g
Beer Mod is offline
post #2 of 18 (permalink) Old 10-14-2007, 01:14 AM
OBS
huh? maybe the glow plugs or harness. it prolly wouldn't be that if it is for sure the elevation that does it.
97 F-250 7.3 psd 4x4: homemade Intake, fpr mod, IDM mod, 18k mod, HX mod, a pillar w/ 3 autometer gauges, 3" downpipe, minus muffler and cat.
stroker_baldy is offline
post #3 of 18 (permalink) Old 10-14-2007, 01:51 AM
SLAPS Treasurer
You might want to check and make sure BOTH batteries are good. Sometimes the engine will turn over fine but not get the glow plugs warm enough.
Chris
97 F-350 cc srw 4X4,White,Cab hi Leer,4.10's,Hypermax H2E turbo,BDP stage 1 injectors and fuel system,BTS tranny and dual HPOP,Banks intercooler,4-pos. chip programmed by Tony Wildman,Joe Servo idm,Tymar intake and hx mod,missing kitty,4" exhaust before rear wheel,Skyjacker 4" system,35" BFG's w/Weld wheels,Amsoil dual bypass filterw/Amsoil syn. oil and diff. lube.
SLAPS treasurer
ytee is offline
post #4 of 18 (permalink) Old 10-14-2007, 02:05 AM Thread Starter
JUCK FEEP
Beer Mod's Avatar
It never wants to start for the first time over night above 4,000ft (when it's cold), but maybe it just gets colder at night..? No mater where I am it's about 30* out when I go to work, maybe the higher elevation just gets that much colder at night???
How cold dose it have to be before these trucks start to have issues with cold start? Should I get a block heater?
Singles Club #80
Ridin' High #32
My Buggy Videos
Beer Mod is offline
post #5 of 18 (permalink) Old 10-14-2007, 02:07 AM Thread Starter
JUCK FEEP
Beer Mod's Avatar
Chris
I will check them for sure. Dose one start the truck and the other run everything else?
Singles Club #80
Ridin' High #32
My Buggy Videos
Beer Mod is offline
post #6 of 18 (permalink) Old 10-14-2007, 02:09 AM
SLAPS Treasurer
Assuning your batteries and glow plug system are operating correctly Ford says that you do not need to plug in till it gets below 0 F. I usually try to plug mine in around 20-25.
Chris
SLAPS treasurer
ytee is offline
post #7 of 18 (permalink) Old 10-14-2007, 02:12 AM Thread Starter
JUCK FEEP
Beer Mod's Avatar
Sounds like something is not working quite right.....
Singles Club #80
Ridin' High #32
My Buggy Videos
Beer Mod is offline
post #8 of 18 (permalink) Old 10-14-2007, 02:24 AM
Super Moderator
John_G's Avatar
The GPs are controlled by coolant temperature and believe it or not, barometric pressure.
Why? Diesels require heat from the compression to ignite the fuel. As altitude increases barometric (atmospheric) pressure decreases, so you make LESS heat in the cylinder because you are compressing less air mass into the same space.
You may have a BARO sensor that is not working correctly, your symptoms sure point in that direction.
I vote for LIBERTY!
John_G is offline
post #9 of 18 (permalink) Old 10-14-2007, 02:28 AM
Kip
In the passing lane
Kip's Avatar
change your glow plug relay that is my guess
2005 2500HD DIRTYMAX 6in lift, dual exhaust, afe airbox. Tuner soon to come
2001 PSD shortbed crewcab, ATS tranny edge juice w/attitude, Superchips programmer, Gauges, exhaust, 4inch lift w/35s, (SOLD)
Originally Posted by sledneck57
Your sweating like a queer holding a hot dog.lol.
Kip is offline
post #10 of 18 (permalink) Old 10-14-2007, 02:33 AM Thread Starter
JUCK FEEP
Beer Mod's Avatar
So it would make sence then that it will start after several cranking attempts, because there is heat built from this....?
Singles Club #80
Ridin' High #32
My Buggy Videos
Beer Mod is offline
