boost prob still - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stroker_baldy, this thread has received 20 replies and been viewed 1218 times.
post #1 of 21 (permalink) Old 10-15-2007, 03:10 AM Thread Starter
OBS
boost prob still
I just took off the elbow and boots and checked the rest of the system. I taped the elbow, put boost gauge into it and cleaned and check the boots. Still only 7 lbs. of boost. compressor wheel looks and feels good. 2 gauges don't lie. I am so lost. help
97 F-250 7.3 psd 4x4: homemade Intake, fpr mod, IDM mod, 18k mod, HX mod, a pillar w/ 3 autometer gauges, 3" downpipe, minus muffler and cat.
stroker_baldy is offline
post #2 of 21 (permalink) Old 10-15-2007, 03:11 AM Thread Starter
OBS
is there anything that can test the turbo (while in truck)?
post #3 of 21 (permalink) Old 10-15-2007, 04:05 AM
Got Diesel's Avatar
you ever check the up-pipes?
Also make sure you have no kinks in the boost line.
Kyle
Early 99 F-250SD 7.3 PSD 4x4. Auto, tymar type intake, straight pipe, Six inch stacks, Tony Wildman Four position chip, Street race, 80 Tow, 80 Econo, Extreme. Let the smoke roll. Upgraded torque converter. Autometer Ultralights on the Pillar. Running Cooper Discover STT's.
Got Diesel is offline
post #4 of 21 (permalink) Old 10-15-2007, 04:08 AM Thread Starter
OBS
wouldn't it be loud if it was leaking. spray soap and see if it bubbles?
post #5 of 21 (permalink) Old 10-15-2007, 05:12 AM
Under what conditions are you seeing 7lbs of boost? 3200 rpm in 3rd or 4th with the throttle on the floor or just cruising down the freeway maybe with a little load?
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #6 of 21 (permalink) Old 10-15-2007, 05:16 AM Thread Starter
OBS
from o to over 90mph(unloaded). pedal to the floor.
post #7 of 21 (permalink) Old 10-15-2007, 05:16 AM
biz
if his stock map sensor was totally shot.... wouldnt he make less power... so less boost?
2000 F-350 Super cab, Tadds tunes, AFE Pro Guard intake, 4" MBRP cool Duals, Nexus Gauges , Tubonetics Ball Bearing Turbo.
biz is offline
post #8 of 21 (permalink) Old 10-15-2007, 05:18 AM Thread Starter
OBS
how often does the map sensor go back? never read a post about it before. how could that be checked?
post #9 of 21 (permalink) Old 10-15-2007, 11:41 PM
Is this a "New" condition after a certain mod?
Does it smoke real bad?
You can check the end play of the turbo by removing the intake and pulling/pushing on the wheel. Should be zero play...
Slated4Greatness is offline
post #10 of 21 (permalink) Old 10-16-2007, 01:40 PM
I have heard of them going bad before but not real often.
I'm not real sure how to check an OBS MAP sensor. They have a digital signal that is sent to the pcm. Best bet would be to hook it to the scanner and see what it says the boost psi is and compare it to your gauge.
Eric
Dually Club Member #53
racehauler is offline
