Surgeing problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dbunyip, this thread has received 6 replies and been viewed 588 times.
post #1 of 7 (permalink) Old 10-15-2007, 04:40 AM Thread Starter
Surgeing problem
on my 99 it seems to be developing a surging problem when driving in what i would call a normal fashion. Right around 1200 rpm until about 2200 rpm. would this be what i've read about the turbo on these trucks? if so, is it something that should show up on the boost gauge? Also It does not do it if i'm in the throttle hard. it just seems to me that a turbo problem would be worse with a heavier load on it. any thoughts would be very helpful.
dbunyip is offline
post #2 of 7 (permalink) Old 10-15-2007, 05:08 AM
Check the TPS and CPS, those can kind a cause a surge. Turbo surge will be both heard and seen on the boost gauge.
1040 WreckerMan is offline
post #3 of 7 (permalink) Old 10-16-2007, 03:16 AM Thread Starter
it just got a cps about 3 months ago so i hope thats not it. (I got raped at the stealership on that one) It doesn't sound any different. It really just feels like I'm letting off the throttle which was my first thought cause we have crappy roads around my home. That make it sound like the TPS? If so, is there a way to test it?
dbunyip is offline
post #4 of 7 (permalink) Old 10-16-2007, 03:41 AM
Feels like your letting off the throttle? That really wouldn't be what I'd call a surge. You can ohm out the TPS and see if there are any worn spots in it. Have you checked your ICP and IRP duty cycle? Those might be an indication of what's going on. Also, if you have the scanner hooked up, when the truck surges check out what desired fuel and TPS values show.
post #5 of 7 (permalink) Old 10-16-2007, 04:38 AM
Super Moderator
John_G's Avatar
Bad wiring to or from the IPR valve can cause this, the incorrect oil type will cause this, as will extended oil drain intervals with even the right oil type.
I vote for LIBERTY!
John_G is offline
post #6 of 7 (permalink) Old 10-16-2007, 05:51 PM Thread Starter
I guess I worded that wrong, it doesn't just back off, its like I was on a rough road and can't keep the throttle steady but thats not what is happening. I'll get ahold of my bros scaner and see if I can find anything. its had delo 400 in it ever since i've had it and its done at 5k.
dbunyip is offline
post #7 of 7 (permalink) Old 10-16-2007, 07:33 PM
Super Moderator
John_G's Avatar
Could the EBP valve be cycling?
I vote for LIBERTY!
John_G is offline
