cold starting - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by joebob3093, this thread has received 9 replies and been viewed 627 times.
post #1 of 10 (permalink) Old 10-16-2007, 12:00 AM Thread Starter
joebob3093's Avatar
Send a message via Yahoo to joebob3093
cold starting
i am going to school in larimie WY, right now and i was wondering what can i do to make it easier to start in the mornings???? thanks
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
post #2 of 10 (permalink) Old 10-16-2007, 12:31 AM
CSIPSD's Avatar
Are you having issues now? I remember running a GPR and GP test on it this summer...
Plug it in if you can, that will help. Cycle the key a few times before you crank in the AM...
CSIPSD is offline
post #3 of 10 (permalink) Old 10-16-2007, 01:44 AM Thread Starter
joebob3093's Avatar
ya it wouldnt start this morning i cycled it twice before i cranked on it. the bad this is they wont let us ran a cord to plug them in at night.
post #4 of 10 (permalink) Old 10-16-2007, 01:56 AM
CSIPSD's Avatar
Might try a new GPR from NAPA for $30... GPR-109 is the part... But I doubt its the problem... Might have a weak Glow plug or two...
CSIPSD is offline
post #5 of 10 (permalink) Old 10-16-2007, 03:18 AM Thread Starter
joebob3093's Avatar
i changed the GPR at your house at the "tech day", how do yu check the glow plugs?
post #6 of 10 (permalink) Old 10-16-2007, 03:57 AM
If you are not already running a synthetic oil ya might consider it. I run the 5-40 Rotella and she spins a bit easier in the morning.
IDPisan is offline
post #7 of 10 (permalink) Old 10-16-2007, 04:27 AM Thread Starter
joebob3093's Avatar
i am running a synthetic 15-40 blend right now
post #8 of 10 (permalink) Old 10-16-2007, 04:33 AM
If the GP have some time on them you most likely have one or more bad ones. You can ohm them.
1040 WreckerMan is offline
post #9 of 10 (permalink) Old 10-16-2007, 05:27 AM Thread Starter
joebob3093's Avatar
how often do they go bad? i think i replaced them in dec. of 05
post #10 of 10 (permalink) Old 10-16-2007, 06:03 AM
Super Moderator
John_G's Avatar
How often do GPs on a PowerStroke go bad? Almost never. I have replaced exactly 3 since they came out in '94, and two of those tried to sink 115V when the injector harness shorted out to them = POOF!
What typically happens is that the UVC connectors and/or terminals get toasty, do not make good contact any more, and the GPs do not get up to full temp because there is high resistance in the UVC harness connectors.
The END terminals of the UVC connector are for the GPs, you can use a test light connected to BATTERY POWER and touch each of the outermost terminals on the UVC connectors (2 on each connector), and if the test light lights well (just like you stuck it to ground) then that GP and wiring from the terminal to the GP are OK.
I vote for LIBERTY!
John_G is offline
