Ceramic Coating - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bgff250, this thread has received 6 replies and been viewed 838 times.
post #1 of 7 (permalink) Old 10-17-2007, 12:26 AM Thread Starter
Ceramic Coating
Does anyone out there know if putting a ceramic coating on your intercooler pipes is worth anything. I see that one of my stock pipes has a heat foil over one of them and I want to clean it up after I purchase a new intercooler.
bgff250 is offline
post #2 of 7 (permalink) Old 10-17-2007, 01:55 AM
For a highly modified truck that's trying to squeeze out every bit of power? Yes.
For a stock or mild truck, no.
Also, that "heat foil" you see is actually sound deadening. Does nothing for temps. Apparently too many old folks complained to Ford that the turbo was too loud.
Pocket is offline
post #3 of 7 (permalink) Old 10-17-2007, 02:50 AM
Ceramic coating is more of a big power thing. Just have em powdercoated.
ckbed is offline
post #4 of 7 (permalink) Old 10-17-2007, 07:26 AM
Ceramic coating on the IC pipes will HURT you more than help you. You want to dissapate the heat in the pipes not hold it in. you most likely wouldn't notice any difference one way or the other but it's the wrong application for ceramic coating. If you want to ceramic coat stuff do the exhaust components.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #5 of 7 (permalink) Old 10-17-2007, 06:32 PM
doesnt ceramic dissipate heat which would be why its on sparkplugs.
tkdbf350 is offline
post #6 of 7 (permalink) Old 10-17-2007, 06:50 PM
CSIPSD's Avatar
No, it holds heat in, that is why you want it on your up pipes and stuff, Heat is drive pressure energy...
CSIPSD is offline
post #7 of 7 (permalink) Old 10-17-2007, 06:55 PM
Ceramic coating is used as an INSULATOR.
Porcelain is used in spark plugs because it does not conduct electricity and is able to withstand the temperature of combustion.
Eric
Dually Club Member #53
racehauler is offline
