what does it take - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2tonePSD, this thread has received 11 replies and been viewed 793 times.
post #1 of 12 (permalink) Old 10-18-2007, 05:27 AM Thread Starter
2tonePSD's Avatar
what does it take
I would like to get a pretty good amount of black smoke. I have a 5" straight pipe exhaust and a Ts chip and i was wondering what else do i have to do. I know that bigger injectors will do a good job of it, but i don't really have the money for that right now. i wasn't sure if there was anything i could do, or if i have to wait and get injectors.
RIP.......
96 F-350 Regular cab: 5" to 6" exhaust. autometer Z series a pillar pod for gauges. Window tint.
2tonePSD is offline
post #2 of 12 (permalink) Old 10-18-2007, 06:14 AM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
you could get a smoke tune burnt on to a chip or you could do DIY injectors. they are pretty cheep and i havnt heard anything bad about them.
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
post #3 of 12 (permalink) Old 10-18-2007, 06:16 AM Thread Starter
2tonePSD's Avatar
ok i knew that injectors would be the way to go, but how cheap is cheap? just wondering. o there can i go and get that burned into my chip?
RIP.......
2tonePSD is offline
post #4 of 12 (permalink) Old 10-18-2007, 06:38 AM
You could put a rag over your air filter. If all you want is smoke then that'll be your best and cheapest way to do it.
466 on #2 only
739 with N≤O
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #5 of 12 (permalink) Old 10-18-2007, 02:31 PM Thread Starter
2tonePSD's Avatar
by cheap i mean just not like over $1,500. i don't want to do something like that.
RIP.......
2tonePSD is offline
post #6 of 12 (permalink) Old 10-19-2007, 05:14 AM
joebob3093's Avatar
i would go with http://www.diy-injectors.com/ i think they are around $300 for stage 1s
post #7 of 12 (permalink) Old 10-19-2007, 06:00 AM
circle5's Avatar
Check out www.Dpppower.com
circle5 is offline
post #8 of 12 (permalink) Old 10-19-2007, 08:07 PM
strokin now cummin later!
Orangepstroke's Avatar
if you wanting your truck to smoke longer get a low stall torque converter and a big a** turbo. that way it takes for ever to spool. but i would go with the injectors. that way you get a little power increase
Erik, 2001 psd 4x4 lariat ext cab pulling truck
Ts 140hp 6pos chip, 100hp split shots, stealth 2 pump,h2e turbo, tranny, afe stage 2,
5" exhaust turbo back, 10" stack, 3.9k mod on a switch, shimmed fpr,hx crossover hose, tc lock up switch. Custom weight rack and ladder bars, f550 springs, custom paint,5%+15% window tint, clear lights,custom billet grille, very big stereo, 20x10 moto meatals wrap with 33x13.50x20 ss iroks
1996 2500 12v 2wd auto reg cab, flat bed, afc mods, sdx 140hp sticks, 4gsk, 60lbs springs, 191dv's, head studs, 16* timing, phat shaft 62/65/14 no plate, exhaust, intake, tanny, auto meter, adjustable overflow valve.
Singles Club #42
Orangepstroke is offline
post #9 of 12 (permalink) Old 10-19-2007, 10:12 PM
smoke is bad, its unburnt fuel which means you're running inefficiently. The fact you don't have smoke means you're doing a good job at burning all your fuel completely. .. and probably getting good mileage too.
now, to the question. You have small injectors, you have way less fuel than the air coming into the engine, you will never smoke that much. . .even w/a smoke tune. The only way to make smoke is reduce the amount of air going into the engine. . .a good boost leak would probably help things out. Maybe drill and tap the wye feeding from the turbo into the engine and put a valve on it. . .you could open it when you want to make smoke.
Really though, anything you do to make your truck smoke will reduce the power. Smoke doesn't make power. The guys running big injectors and big turbos have smoke only cause we dont' have as much air as we'd like to be getting. . .that's why some have choosen compound turbos to clean things up, others have choosen NOS, and others are waitning for the money to do one of the above. Do your diesel brethren a favor, save the smoke for the track, smoking on the street just gives us all a bad name.
-Brad Desatnik
trick76cj5 is offline
post #10 of 12 (permalink) Old 10-19-2007, 10:13 PM
Didn't Andrew try this once? But he tried putting it on the inside of the filter. . . i'm not sure which would be more productive? :
-Brad Desatnik
