Got the truck! (HELP) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Cummins_Beast, this thread has received 14 replies and been viewed 814 times.
post #1 of 15 (permalink) Old 10-19-2007, 05:38 AM Thread Starter
Formerly F350_Beast
Cummins_Beast's Avatar
Ok, so I am now an official PSD owner. I'm so excited! Having some minor problems though. The blinkers/taillights/flashers don't seem to work right. Fuses are all good. I can get the rear blinkers and tail lights to work, but the front right blinker doesn't. The flashers don't work either. Anyone have any input?? Trying to get the beast inspected and it won't pass right now. Thanks! :Thumbup:
Cummins_Beast is offline
post #2 of 15 (permalink) Old 10-19-2007, 07:36 AM
Formerly NATTYGASMECH
Canyon JYD's Avatar
Kind of curious if you have checked the bulbs?
Canyon JYD is offline
post #3 of 15 (permalink) Old 10-19-2007, 08:43 AM
Did you check or replace the flasher relay?
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #4 of 15 (permalink) Old 10-19-2007, 02:00 PM
bulbs would be my bet... not to insult your intelligence or anything. try the bulbs
early '99 converted to late '99 F-350 dually, 4x4, 4 door, long bed, 6 speed. Midwest transmissions 05+ zf-6 transmission with their short throw shifter and SB clutch. Rosewood 180cc with 80% nozzles, Termy modded 17* HPOP, International bellowed up pipes, fs-2500, DP Tunes. A few other things here and there...
dually club member.. Why replace 5 tires when you can replace seven? I like my training wheels...
calebgriffin31 is offline
post #5 of 15 (permalink) Old 10-19-2007, 02:27 PM
flasher
2001 Ford X with Racer X Trans and DP tuner
2003 Yamaha Rx1 with Turbo 300hp
2008 Yamaha Rtx Nytro Supercharged !!HAHAHA
25' Motion Cat twin 280 Merc offshores 118 mph
skydog is offline
post #6 of 15 (permalink) Old 10-19-2007, 03:03 PM
JD
Diffently check bulbs up front you said you got rear working,if half the bulbs are bad the flasher unit will be slow it needs all amperage draw to work properly.The emergency flasher unit is on backside of fuse block turn signal towards interior of truck.double check fuses the turn and parking lights use seperate fuses
fuelman is offline
post #7 of 15 (permalink) Old 10-19-2007, 04:18 PM
If any of the problems are sporadic or have changed as you have worked on it then, it is a grounding problem. If your truck is from the North or upper midwest and been driven on those salty roads, clean all your ground connections.
D-Man is offline
post #8 of 15 (permalink) Old 10-20-2007, 12:27 AM
pontiacross's Avatar
it could be your turn signal switch. I think the same flasher works the fron and rear blinkers so if they are working in the back that shouldn't be your problem. the front and rear blinkers are seperated out in the turn signal switch because the brake lights use the same wires abd bulbs as the rear blinkers. find your switch and use a test light to check for power at the wires. while the turn signals are on you should have three wires blinking the one comming from the flasher, one goes to the rear and one to the front if you only have 2 your switch is bad.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #9 of 15 (permalink) Old 10-20-2007, 01:17 AM
Diesel Enthusiast
I have replaced a few of the turn signal / flasher switch relays in the OBS trucks myself, they are prone to failure, easy fix though.
2002 F250 Extended cab XLT 4X4 long bed.
Intake, muffler delete, DP-Tuner
1997 F250 Regular cab 5 speed 4x4.
3in Downpipe, Stage 1 sticks, solid flywheel conversion, 6 position chip. Work truck.
5gear is offline
post #10 of 15 (permalink) Old 10-20-2007, 07:11 AM Thread Starter
Formerly F350_Beast
Thanks for all the replies. I did check the bulbs, they seem to be fine, and all work sometimes. I also replaced the flasher relay, and checked all the fuses. I didn't check the ground though, where might that be? Can't seem to find it, lol. Thanks guys!
// BENNY \\
14.7 @94mph
// 2006 Dodge Ram 2500 5.9 Cummins QC 4x4 Laramie \\
// 4" Lift, 35" Nitto Mud Graps, 20" Moto Metal 955's \\
// Silencer Ring M.I.A, aFe Mega Cannon, Edge Juice w/ Attitude, 5" TBE \\
'97 F350 SOLD
--RIDING HIGH CLUB MEMBER #4 --
SINGLES CLUB MEMBER #95--
