still 25 psi max - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by HotSauce2138, this thread has received 9 replies and been viewed 852 times.
post #1 of 10 (permalink) Old 10-19-2007, 01:45 PM Thread Starter
Hotsauce2138
Send a message via AIM to HotSauce2138 Send a message via MSN to HotSauce2138
Unhappy still 25 psi max
ok i got the boost fooler and now it only gets 25 psi max and when i had the lil red line off the turbo it would get 30 butr would throw the check engine light so what could i have possibly done wrong, i thought anybody could install a boost fooler?:shrug:
SAM
Late 99 F-250 CC SWB Lariat 6 sp. 4x4 - the mods= Garrett GTP38R Turbo, DDP Stage 2 Single Shot Injectors. Shimmed Regulator, CCV Reroute and HX Hose from Dfuser, 4" turbo back straight pipe to GR 5" stack kit w/ 7"mitre cut stacks DPPPOWER.COM, AFE Stage 2 Intake w/ PG7, DP Tuner F5 Chip, 18K Mod Dfuser, SouthBend Clutch, Pro Pods quad a-pillar pod, Autometer Ultra-Lite Series Guages ( EGT, Boost 0-35, Trans Temp, Fuel Pressure and Engine oil temp.), Pro tech cab guard, WELD Sidewinders. Road Armor's!!! Custom Pro Tech toolbox/stack cover, , Sirius Sat. Radio, BD Exhaust Brake, 06 Towing Mirrors w/ LED blinkers and heated
:93C_peelo
My Gallery: http://fordtruckworld.tenmagazines.c...y.asp?id=18074
Singles Club Member #52
Can You Keep Up??
Because I'm trying to. lol
HotSauce2138 is offline
post #2 of 10 (permalink) Old 10-19-2007, 05:21 PM
what kind of boost fooler are u using?? im using the one from D-fuser and i am getting around 25psi with no chip and 32psi with the chip look in my sig and thats what i run.. i also have no waste gate to so may be some of this could help in diagnose ur problem
strokedout_07 is offline
post #3 of 10 (permalink) Old 10-19-2007, 06:03 PM
Are you still getting the SES?
Check your IC boots.
Check your up pipes.
Check for a kink in the boost guage line.
Just a couple of thoughts..
Slated4Greatness is offline
post #4 of 10 (permalink) Old 10-19-2007, 06:36 PM
CSIPSD's Avatar
Are you checking to see what the SES light is for, or are we just assuming its the overboost?
CSIPSD is offline
post #5 of 10 (permalink) Old 10-19-2007, 06:39 PM
CSIPSD's Avatar
Also sounds like you need to ajust the wastegate tighter, you should be seeing 32-35# with those injectors.
CSIPSD is offline
post #6 of 10 (permalink) Old 10-19-2007, 06:48 PM
If your boost gauge is T'ed into the MAP hose it must be between the engine and the regulator. If you have a blow off type MAP fooler then the T needs to be as close to the engine as possible.
Sounds to me like you either have the T for you gauge between the regulator and the map or it is too close to the Blow Off Valve.
Eric
Dually Club Member #53
racehauler is offline
post #7 of 10 (permalink) Old 10-19-2007, 07:12 PM
Mafia Member #93
blk99's Avatar
:iagree thats definatly what it sounds like.
blk99 is offline
post #8 of 10 (permalink) Old 10-20-2007, 02:54 AM Thread Starter
Hotsauce2138
ok i have the boost fooler from d2hiperf aka dave the t kind and i have a t fitting for my boost gauge, but i put the boost t fitting between the motor and boost fooler. i did wat the instructions that dave sent me told me to do.
joe- yea i'm just assuming its the over boost light b/c when i would romp on it it would throw the check engine light.
now i checked the y pipes and there is no soot anywhere. so i dont think they're leaking.
anything else?
SAM
:93C_peelo
Can You Keep Up??
post #9 of 10 (permalink) Old 10-20-2007, 10:50 PM
try the fitting that puts the gauge line in the intake air heater spot and see if that helps
tkdbf350 is offline
post #10 of 10 (permalink) Old 11-01-2007, 12:55 AM
i am only seeing about that same psi w/ the mods below and wondering if the bankswaste would take care of that??
imported_99powerstroke is offline
