4R100 is the best trans?????????????? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by StrokerDude, this thread has received 10 replies and been viewed 4355 times.
post #1 of 11 (permalink) Old 10-23-2007, 04:34 PM Thread Starter
StrokerDude's Avatar
Saw it said in another thread and didn't want to take it off topic by asking...
I have never heard anyone say that the Ford has the best Transmission....
What makes it the best?
Alex C.
StrokerDude is offline
post #2 of 11 (permalink) Old 10-23-2007, 04:51 PM
4cstr
This could be a loaded question. I believe that any of the transmissions in the big 3...behind a stock motor...are more than capable of doing what they are supposed to. Once you mod the motor and begin throwing high HP at the stock tranny...you really begin to shorten its life.
Once you begin the process of "building" the tranny to handle the higher motor output...then it no longer becomes an issue of which maker builds the best tranny...but what are the best options for a "built" tranny.
post #3 of 11 (permalink) Old 10-23-2007, 10:03 PM Thread Starter
So, when dealing with a built tranny they are all capable of performing at the same levels???
I asked the question in this post becaue I saw in the commonrail thread that someone said the Ford trans is the best one.
Alex C.
post #4 of 11 (permalink) Old 10-23-2007, 10:05 PM
Slow 6.0
i think the 4r100 is pretty well built from the factory, the torq shift is even better
2006 F350 XLT 4x4
SICKS-O is offline
post #5 of 11 (permalink) Old 10-23-2007, 10:09 PM
If you're referring to what I said I was saying they are the strongest when fully built aftermarket. They hold a lot of torque.
The dodge autos are pretty strong when built as well.
gregrob is offline
post #6 of 11 (permalink) Old 10-23-2007, 10:10 PM Thread Starter
Too bad the torqshift can't be mated to the 7.3
I think from another thread I posted months ago it was determined that it could not be done.
Alex C.
post #7 of 11 (permalink) Old 10-23-2007, 10:11 PM Thread Starter
I believe it is your post that I referred to. I wanted to make sure not to take the other thread off topic.
Alex C.
post #8 of 11 (permalink) Old 10-24-2007, 01:22 AM
I had mentioned something in the other thread about the Ford having the best transmission out there. What makes it the best is BTS. Besdies that the way it shifts as in the physical mechanical characteristics of it (not the feel)is much better than the allison and they seem to be able to hold up to more power than the built dodge trannys and cost about half as much to fully build. Give brian at BTS a call and he can explain it to you pretty well.
The basics of what he was telling me about the Ford tranny vs. the Allison and how they shift is the Allison has to unlock one clutch and lock another. This gives a feeling of the truck slowing down then hitting hard as the 2nd clutch engages. The Ford however has sprag clutches (a one way clutch) so that the 2nd clutch pack engages before the first one completely disengauges makeing the shifts feel like it's pulling the truck out from under you rather than slowing then going again. What the sprag clutch does is it allows the shaft to speed up away from the 1st clutch that is still partially engaged because the first clutch only holds the shaft while under power but if the shaft spins faster than the clutch it will freewheel.
Not sure if I explained that well but hopefully you'll get what I'm saying.
I haven't personally been in these transmissions so maybe someone who rebuilds them regularly can chime in and correct me if and where I'm wrong. This is just how it understood what was explained to me.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #9 of 11 (permalink) Old 10-24-2007, 02:20 AM Thread Starter
VERY INTERESTING!!!!! Great to learn that.
Alex C.
post #10 of 11 (permalink) Old 10-24-2007, 07:27 AM
Like I said don't take it all for gospel that's just the way I understood it when he was explaining it to me. Give Brian a call and pick his brain. Or one of the other tranny builders if they'll talk to you.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
