Very hard start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bmxdirtjumper13, this thread has received 13 replies and been viewed 935 times.
post #1 of 14 (permalink) Old 10-23-2007, 04:38 PM Thread Starter
Very hard start
I have a 97 f-350 crew cab with a edge evolution programmer intake and 3 inch downpipe to 4 inch out. But for some reason now that its colder out only in the 40s to 50s my truck doesnt want to start it cranks for a long time some times i gotta do about 3 cycles of cranking before it chokes then blows a bunch of white and blue smoke then runs fine and starts fine after that what could that be????
bmxdirtjumper13 is offline
post #2 of 14 (permalink) Old 10-23-2007, 04:44 PM
TurboTPI's Avatar
Sounds like you might need some glow plugs my fellow BMXer. Just a guess tho.
92 Firebird Formula 350-Custom turbo setup, 570rwhp, [email protected](daily driver when its nice out)
97 F-250, 4wd, CC, SB, aFe 4in Turbo Back, diy Tymar intake, Edge Evo, CCV Mod, FPR Mod, 1.0 housing, 7.3 SD Cooler
93 Jeep Wrangler 4.0-Up 7in on 36in SS TSL's
09 Polaris Dragon 800SP
TurboTPI is offline
post #3 of 14 (permalink) Old 10-23-2007, 05:14 PM
Send a message via MSN to 7.3 power
Im not sure if the OBS has it but i had the same promblem on my 01 SD i found the glow plug relay was bad, replaced have'nt had a problem since.
2001 Black Larait F250 7.3 powerstroke, CC SB SRW
MODS: Superchip, MBRP 4" straight through exhaust, Turbonetics .84 ar turbo and AFE stage 2 intake
4" suspension lift, 35" BFG MTs, 16.5" American Racing bullet hole wheels, Linex spray in bedliner, clear corner lenses, rear blackouts
7.3 power is offline
post #4 of 14 (permalink) Old 10-23-2007, 07:01 PM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
The OBS has a relay just like the one in the SD. Go to a NAPA and ask for the GPR 109. The relay sits just under and kind of off to the side of the engine cover. Hook the new up just like the old was and your good to go. If you still have cold start issues, then you may need to swap out the plugs. They are under the valve covers and take the average joe about 2-3 hours to replace.
OBS under the hood picture here -> https://www.thedieselgarage.com/forum...ad.php?t=22948
TooLoudTooBad is offline
post #5 of 14 (permalink) Old 11-04-2007, 05:11 PM Thread Starter
how much does this usually run
post #6 of 14 (permalink) Old 11-04-2007, 05:25 PM
Mafia Member #93
blk99's Avatar
The part number for your truck is: ECHGPR110 and it runs about $85.
Jim
blk99 is offline
post #7 of 14 (permalink) Old 11-04-2007, 05:43 PM
TDG Mafia Member #73
Look at your battery meter on the dash when you crank it. If it moves far to the left for a while, your relay is OK. Most likely it is your battery cables. I had this happen to mine a year ago. Changed GP's did not help. New batteries did not help. My cables looked fine but someone told me to change the cables because the same thing happened to him. I bought new cables and it starts faster than ever. Even when it is 0* outside. I got them from www.powerstrokeshop.com.
mattymx is offline
post #8 of 14 (permalink) Old 11-04-2007, 08:21 PM
Jim
109 is about $20.00 at napa...
Rick....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
www.fordtransmissioncure.com
Special thanks to RacerX USA
action4478 is offline
post #9 of 14 (permalink) Old 11-04-2007, 11:27 PM
Just learnin and waitin..
I had this same problem with my truck. Once it started getting in the low fifties and under i had to start plugging it in, and all four glow plugs on the left bank had bubbles on them from overheating them or something. I replaced just those four and i didn't have to plug it in the rest of the winter. even down in the low twenties.
Psd715 is offline
post #10 of 14 (permalink) Old 11-04-2007, 11:38 PM
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
most likely the relay, mine did the same thing last year.
e99 leveled on 35s
250/80, modded s300, studs, springs, push rods, adrenaline, swamps tuning, racerx trans
BigRed97 is offline
