how to get new down pipe in (OBS) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 96 stroker, this thread has received 6 replies and been viewed 948 times.
post #1 of 7 (permalink) Old 10-23-2007, 05:26 PM Thread Starter
i cant get the new one in i tried going from the top and the bottom just cant get it in
96 F350 crew cab long bed. DIY green filter intake 7 inch stacks. stock height .275,000 and still truckin
96 stroker is offline
post #2 of 7 (permalink) Old 10-23-2007, 05:58 PM
circle5's Avatar
is it a 2 peice???
If so put the top in from the top and the bottom in the from bottom.
You'll probaly have to pound the **** out of the firewall to get it so it don't rub. Mine is rubbing right now and the sound is aweful
circle5 is offline
post #3 of 7 (permalink) Old 10-23-2007, 06:47 PM
pontiacross's Avatar
on mine i took rear crossmember off the transmission and let it down a little to gain some room to get it slid in. i also had to beat a body seam down on the fire wall to keep it from rubbing.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #4 of 7 (permalink) Old 10-23-2007, 08:11 PM
You might make a couple of cuts in the lip of the firewall to make it easier to bend back so that the pipe will fit. Not all trucks require this though. It depends on how far up or back the cab is mounted. I've heard of using a jack and 2x4 to bend the lip if you don't want to pound it.
worm drowner is offline
post #5 of 7 (permalink) Old 10-24-2007, 01:27 AM
I would recomend NOT cutting the seam. You will just open it up for rust by doing so and it is not needed. The simplest way to do it is use about a 3' 2X4 and bend the firewall in. You can pry from the back of the head to the firewall from the top and the down pipe and the firewall from the bottom. I have installed a few this way and it works great and you don't have to worry about your heat insulation being cut up or your pinch weld rusting out down the road.
The easiest tool to use is a port-a-power with a duck bill attchment and sometimes a small 6" or so long chunk of 2X4. put it between the transmission bell housing and the fire wall and push the firewall where the down pipe hits.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #6 of 7 (permalink) Old 10-24-2007, 02:38 AM
Found On Russ' Drive
Russ's Avatar
you could also use a small scissor jack to push the firewall back
Duct tape... turning No No No into mmmmmm mmmmmmm mmmmmmm
Stormtrooper::1997 F-350 CC SRW PSD XLT 4X4: 332 hp 660 tq. made with Baby Swamps, Wildman 4 pos chip, 120V IDM, CCV mod, shimmed FPR, BTS E4OD, Baldwin air filter,triple pillar pod with Isspro gauges, 4" MBRP exhaust, SD dual tensioner mod, diamond cut headlights,Recon LED tailgate lights Hadley air horns,
Russ is offline
post #7 of 7 (permalink) Old 10-25-2007, 02:04 AM Thread Starter
i got it guys thanks for all the help
