Where is map sensor line - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kenjudwollam, this thread has received 11 replies and been viewed 8034 times.
post #1 of 12 (permalink) Old 10-23-2007, 08:53 PM Thread Starter
I am instlling guages on my 1996 Ford F350 power stroke. I am not sure where the map sensor line is at. I tap into a short vacuum line from the vacuum pump but the boost guage does not seem to work.
kenjudwollam is offline
post #2 of 12 (permalink) Old 10-23-2007, 09:05 PM
4cstr
I don't have a picture in front of me...but it is a line that goes from the base of the turbo over to the map sensor which is on the passenger side of the engine compartment. I'll see if I can find a picture.
On edit...take a look at this thread. In the one picture you can see it labeled on the left.
post #3 of 12 (permalink) Old 10-23-2007, 09:21 PM
Ford Man
Wes2349's Avatar
I have tapped into the map line but my boost gauge will not work. We tested the gauge and it works fine but the gauge wont show any boost while on the truck. Can somebody give me some help?
(Current)2nd Truck: 2003 Ford F-350 6.0 PSD: 5% Tint, Blacked Out Lights/Badges, 16x10 Black Pro Comps, 305/70 BFG All-Terrains, Black Low-Pro Toolbox, Spray In Liner, Leveling Kit, K&N Intake, Straight Pipe, and more to come.
(Sold)1st Truck: 1997 Ford F-250HD 7.3 PSD: 5% Tint, Spray In Bedliner, Black Low-Pro Toolbox, DIY Intake, DP Tuner, 4" Straight Pipe, American Racing Wheels, and 33's.
Wes2349 is offline
post #4 of 12 (permalink) Old 10-23-2007, 09:26 PM
4cstr
Is this while standing still in the driveway...or on the road under a load or WOT conditions?
post #5 of 12 (permalink) Old 10-24-2007, 03:18 AM
Ford Man
Wes2349's Avatar
The gauge will not move at all going down the road. I checked all connections and they are all hooked up correctly.
Wes2349 is offline
post #6 of 12 (permalink) Old 10-24-2007, 04:05 AM
pontiacross's Avatar
you can see where I taped mine in the map sensor hose here.
it is the black hose on the left hand side of the picture with the white T and small white hose (my boost gauge hose) coming out of it.
Attachment 14083
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #7 of 12 (permalink) Old 10-24-2007, 04:49 AM
Got Diesel's Avatar
My guess is you tapped it into the wrong line.
Kyle
Early 99 F-250SD 7.3 PSD 4x4. Auto, tymar type intake, straight pipe, Six inch stacks, Tony Wildman Four position chip, Street race, 80 Tow, 80 Econo, Extreme. Let the smoke roll. Upgraded torque converter. Autometer Ultralights on the Pillar. Running Cooper Discover STT's.
Got Diesel is offline
post #8 of 12 (permalink) Old 10-24-2007, 06:04 PM Thread Starter
Thanks guys. I found the map sensor line, hooked it up and works fine.
post #9 of 12 (permalink) Old 10-24-2007, 06:06 PM
4cstr
Awesome!
post #10 of 12 (permalink) Old 10-28-2007, 03:43 AM
strokin now cummin later!
Orangepstroke's Avatar
why would you tap into the map senor line? wouldn't it be better to drill and tap into the y-pipe. the boost gauge should come with a threaded fitting to do that. thats what i did with my factory y-pipe.
Erik, 2001 psd 4x4 lariat ext cab pulling truck
Ts 140hp 6pos chip, 100hp split shots, stealth 2 pump,h2e turbo, tranny, afe stage 2,
5" exhaust turbo back, 10" stack, 3.9k mod on a switch, shimmed fpr,hx crossover hose, tc lock up switch. Custom weight rack and ladder bars, f550 springs, custom paint,5%+15% window tint, clear lights,custom billet grille, very big stereo, 20x10 moto meatals wrap with 33x13.50x20 ss iroks
1996 2500 12v 2wd auto reg cab, flat bed, afc mods, sdx 140hp sticks, 4gsk, 60lbs springs, 191dv's, head studs, 16* timing, phat shaft 62/65/14 no plate, exhaust, intake, tanny, auto meter, adjustable overflow valve.
Singles Club #42
Orangepstroke is offline
