swap 4r100 for 5r100? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by strokin350, this thread has received 9 replies and been viewed 7189 times.
post #1 of 10 (permalink) Old 10-23-2007, 10:18 PM Thread Starter
I have a 2002 F-350 as seen in my sig, I am wondering if anyone can tell me if it is possible to replace my stock 4r100 with a 5r100 the reason I ask is cause my tranny has about 147k miles on it and is starting to show some significant signs of wear, and i have access to a 5r100 with a little less than 65k miles on it, from a 2005 F-350 that my buddy totalled.
Thanks,
Chris
strokin350 is offline
post #2 of 10 (permalink) Old 10-23-2007, 10:57 PM
StrokerDude's Avatar
If I remember right from a thread I started a few months ago, you would need some kind of extra controller. Seems like I remember being told that there are two fourth gears in the 5r100 and depending on situation it will use one or the other. I obviously am not completely sure what I am talking about, but somebody that does knows better will chime in soon.
Alex C.
StrokerDude is offline
post #3 of 10 (permalink) Old 10-23-2007, 11:38 PM
Slow 6.0
well the 5 speed auto (torq shift) has a 3.11 1st gear 2.20 2nd 1.54 3rd 1.0 4th and .71 5th the 4r100, 4 speed auto is 2.71 first 1.54 2nd 1.0 3rd and .71 5th. you need to use the ATS standalone tranny ecu setup to run the torq shift, im not sure what they have come up with for adapters yet tho.
2006 F350 XLT 4x4
SICKS-O is offline
post #4 of 10 (permalink) Old 10-23-2007, 11:40 PM
So ATS has a controller that will allow you to run the torqshift on other motors??
Alex C.
post #5 of 10 (permalink) Old 10-23-2007, 11:50 PM
Slow 6.0
yes.
2006 F350 XLT 4x4
SICKS-O is offline
post #6 of 10 (permalink) Old 10-24-2007, 12:17 AM
Mafia Member #93
blk99's Avatar
Just get a built 4R100. It would probably be the same amount of money to switch to the 5R110 and you will have a much, much stronger tranny.
blk99 is offline
post #7 of 10 (permalink) Old 10-24-2007, 01:42 PM
Former Ford AutoTrans Eng
Mark_K's Avatar
Originally Posted by Power Stroke
well the 5 speed auto (torq shift) has a 2.91 1st gear 1.75 2nd 1.34 3rd 1.0 4th and .71 5th
The correct ratios:
1st - 3.11:1
2nd - 2.2:1
3rd - 1.54:1
4th - 1:1
5th - 0.71:1
reverse 2.88:1
Mark
Former Ford Automatic Transmission Engineer 1988-2007
Mark_K is offline
post #8 of 10 (permalink) Old 10-24-2007, 04:05 PM
CSIPSD's Avatar
I would build the 4r100 before I would swap in a 5r110...
CSIPSD is offline
post #9 of 10 (permalink) Old 10-24-2007, 05:46 PM
I would agree, the controller alone will probably run about $1000 (that's about what the PCS controller runs anyway), then add adapters and the rest. A good built tranny will cost a total of $4500 complete, and the 4R100 is an all around better tranny than the 5R110 once built.
-Brad Desatnik
trick76cj5 is offline
post #10 of 10 (permalink) Old 10-25-2007, 05:42 AM
the downside is a four speed instead of a five
Alex C.
