Newbie has diesel smell in cab question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dpuhl, this thread has received 6 replies and been viewed 1462 times.
post #1 of 7 (permalink) Old 10-24-2007, 04:09 PM Thread Starter
Cool Newbie has diesel smell in cab question
Just bought a 1997 Ford F350 Crew with the 7.3 and the Banks PowerPack and Banks Brake installed in it. This is my first diesel vehicle and I have hopefully a simple question.
When at idle, I get diesel smell in the cab. Is this normal for a diesel, or, should I be looking for a leak somewhere.
Thanks...Dave...
dpuhl is offline
post #2 of 7 (permalink) Old 10-24-2007, 04:31 PM
JD
Check to see if it still has orginal exhaust downpipe on it.This item comes off the turbo if it is orginal it will be kinda flat between engine and firewall. Both of mine had cracks in them under the heat shielding.You can have someone start truck while you watch for smoke.If bad you can replace with new round one for about $100.
Other thing is look around top of engine near fuel filter housing and in valley below for leaks.
fuelman is offline
post #3 of 7 (permalink) Old 10-24-2007, 05:28 PM Thread Starter
Re:
It has aftermarket downpipes with what looks to be a neoprene connectors. I did notice one morning when starting it, I did get a little smoke from the engine compartment.
The gentleman who owned it did a great job installing the turbo kit, and brake. I guess he said he also installed the Banks stainless steel exhaust system; upgraded the transmission and was very adament about changing the oil every 3,000 miles and keeping the truck lubed. He also said he had a 60 gallon tank in the bed and had it plumbed into the fuel system. He said that if I want to add a tank to the bed, all I have to do is to remove the rubber fitting (cap) and run the gas line into the 'tee'.
Does anyone know what FW16 is?
He said he adds it to the cooling system to help reduce water pitting in the block.
I will have the downpipes checked for cracks and/or leaks. I will also check the front of the engine as suggested.
Thanks...
Dave....
dpuhl is offline
post #4 of 7 (permalink) Old 10-24-2007, 08:57 PM
Wink
there is only one downpipe, maybe you are talking about the hoses from the intakes (there are two coming from the Y pipe).
the FW16 is a coolan additive to prevent cavitation in the motor.
The little smoke from the engine compartment could be a blow by, maybe some one else chime in, because it could be normal but it all depends of the amount of smoke.
Good luck.
BTW welcome to the TDG.
STROKER#1 is offline
post #5 of 7 (permalink) Old 10-25-2007, 04:29 AM
i had fuel that leaked into the valley and it smoked a bit from the engine compartment for a few minutes. I would check the fuel filter drain valve maybe, could have a leaking o-ring there.
sirnunya is offline
post #6 of 7 (permalink) Old 10-25-2007, 04:44 AM
Formerly F350_Beast
Cummins_Beast's Avatar
Are you smelling actual diesel fuel? Or is it more like an exhaust smell? I would park somewhere that you can easily see if something is leaking. Maybe even put a big piece of cardboard under the truck and just go from there. Good luck!
// BENNY \\
14.7 @94mph
// 2006 Dodge Ram 2500 5.9 Cummins QC 4x4 Laramie \\
// 4" Lift, 35" Nitto Mud Graps, 20" Moto Metal 955's \\
// Silencer Ring M.I.A, aFe Mega Cannon, Edge Juice w/ Attitude, 5" TBE \\
'97 F350 SOLD
--RIDING HIGH CLUB MEMBER #4 --
SINGLES CLUB MEMBER #95--
Cummins_Beast is offline
post #7 of 7 (permalink) Old 10-25-2007, 04:59 PM Thread Starter
Re:
I'm sorry for my description.
It is exhaust smell I get. I have already checked for fuel and oil leaks and have found nothing is leaking.
The smoke I saw was one morning when I started up. I saw just a small puff as soon as the engine started. It does not continue to smoke.
I am going to take it to a repair shop that specializes in diesels and have them check the downpipe. They seem to be pretty honest. They are the ones I had check the truck out before I bought it.
I have a LOT to learn! I really appreciate all the responses.
This truck sure beats my old 1988 F-350 with the 460 gas engine. No comparisons.
dpuhl is offline
