no throttle response - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by powerstrokin94, this thread has received 10 replies and been viewed 6927 times.
post #1 of 11 (permalink) Old 10-24-2007, 05:48 PM Thread Starter
The other day i was driving along not getting on the truck at all and the SES light came on and i lost most of the throttle response. i pulled over and shut the truck down and restarted it and it was fine. the past couple of days i have been driving it with no problems. Any ideas?
Thanks
Andrew
powerstrokin94 is offline
post #2 of 11 (permalink) Old 10-25-2007, 01:16 AM
pontiacross's Avatar
sounds like the throttle position sensor. My truck did the exact same thing. you have to replace the whole throttle peddle assembly unless something new is out since I did mine.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 11 (permalink) Old 10-25-2007, 07:20 AM Thread Starter
do you know how much that costs?
post #4 of 11 (permalink) Old 10-25-2007, 01:57 PM
rock removal technition
also possibility of a CPS, need to know the codes.
If I remmber the throttle pedal was discontinuded or something.
also was it raining, or did ya just wash the truck?
double-s-diesel is offline
post #5 of 11 (permalink) Old 10-25-2007, 02:11 PM
Look Here....
& here....
Rick....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
www.fordtransmissioncure.com
Special thanks to RacerX USA
action4478 is offline
post #6 of 11 (permalink) Old 10-25-2007, 03:53 PM
01PlatinumEdit's Avatar
I had a similar experience this morning - pulled out onto the main road and there goes the throttle response down to almost nothing. Engine was still warming up, but I wasn't on it at all. I was able to get the rpms back up but then it did it again. Finally got it back and was good all the way into work, but now I'm nervous. Also noticed a puff of bluish-white exhaust as it was happening. Is this still likely to be the throttle position sensor???
01PlatinumEdit is offline
post #7 of 11 (permalink) Old 10-26-2007, 04:47 AM
are you compleetly looseing your throttle or dose it just feel like it dosent have any power?
Ross
Tow Rig
post #8 of 11 (permalink) Old 10-26-2007, 02:14 PM
basically just sputtered out and RPMs just dropped to idle then lower. I got off the pedal, then back on it, off, on and it gradually came back up. Did it twice yesterday morning.
I changed out the CPS last night and the truck started and ran fine this morning. Hoping that's all it was. But I thought that when a CPS croaks you were dead in the water and not intermittent though?
post #9 of 11 (permalink) Old 10-28-2007, 11:28 AM Thread Starter
It was raining out, but i have been driving it for a week without any problems. someone mentioned to me it was because of the 18k mod, so i have had that off and had no problems. CPS is relatively new, but i know they can take a **** at any time. thanks
post #10 of 11 (permalink) Old 10-28-2007, 08:06 PM
it can be intermittent like that too.
Ross
Tow Rig
