7.3L IDM replace, need help. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jimbotismo, this thread has received 14 replies and been viewed 19238 times.
post #1 of 15 (permalink) Old 10-25-2007, 04:07 PM Thread Starter
Red face 7.3L IDM replace, need help.
I need to locate the injector drive module for my 1999 f350 7.3L.
I also need replacement instructions,
thanks.
jimbotismo is offline
post #2 of 15 (permalink) Old 10-25-2007, 04:16 PM
DIESEL FREAK
dieslpower97's Avatar
thanks.
bad link removed - went to incorrect thread - TDG staff
1997 DIY intake, AFE exhaust, DP tuned, idm mod, fuel pressure mod, Stancor GPR, dual electric fans......and a whole lot more someday! SOLD!!!
2002 F350 Single Wheel Crew Cab XLT 4x4 165k
OBAMA SUCKS MAJOR
dieslpower97 is offline
post #3 of 15 (permalink) Old 10-25-2007, 07:31 PM Thread Starter
Smile Thanks for the info
Thank you for the information on replacing the IDM in my truck.
You were very helpful, I appreciate it very much.
post #4 of 15 (permalink) Old 10-29-2007, 01:11 AM
bushpilot's Avatar
check here before for you buy one from a dealer (rumored at 900 bucks)
199/249/349 for the IDM here...and that includes either
a 180day warranty (on used/tested good) or 1year on a new/rebuilt !
Auto Computer Exchange
Don R.
Truck Audio,
bushpilot is offline
post #5 of 15 (permalink) Old 05-19-2010, 08:35 PM
The link here takes me to a thread title "Damn Thieves" - could someone provide an accurate link to help me out with the same issue? I need it fairly quick. Thanks in advance.
brettdacosta is offline
post #6 of 15 (permalink) Old 05-19-2010, 08:41 PM
plainredtruck's Avatar
Images: 11
bad link removed
The IDM is under the inner fender on the driver's side.
It's a silver box (IIRC).
You need to unhook your batteries, removing the driver's front tire is helpful, remove inner fender, remove IDM, replace.
Not too difficult.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
The Following User Says Thank You to plainredtruck For this addition to TDG:
brettdacosta (05-19-2010)
post #7 of 15 (permalink) Old 05-19-2010, 08:45 PM
Thanks for the description - is the correct link located somewhere else? I feel much more comfortable with pictures - but if not, I'll give it a go. Thanks again for the lightning fast response.
post #8 of 15 (permalink) Old 05-20-2010, 04:47 AM
easy money's Avatar
feel out the your signature.....
My IDM is an easy one...on a 1995 just 4 bolts and its off.
search it on the web.
1995 f250 2wd PSD, auto, DIY intake, DIY exhaust, PHP tuned 40hp tune , Hybrids injectors 238cc..... 13.618 in the 1/4 at 6000lbs.
1995 GMC 3500HD dump truck 6.5 turbo(lol) DIY intake and exhaust.
2008 GMC 2500 hd stock for now.EFI LIVE installed!!!!!
easy money is offline
post #9 of 15 (permalink) Old 05-22-2010, 02:54 PM
balz out's Avatar
is the idm in the back or front of the drivers side wheel well?
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #10 of 15 (permalink) Old 05-22-2010, 08:43 PM
balz out's Avatar
cancel that
balz out is offline
