Loud engine noises - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Grummin, this thread has received 13 replies and been viewed 1034 times.
post #1 of 14 (permalink) Old 10-28-2007, 02:04 AM Thread Starter
Grummin's Avatar
Loud engine noises
Ok Engine and Tranny gurus,
I filled the tank up this afternoon with diesel not gas went into the store and came back out and started the truck up. I noticed that there was this noise coming from the engine area it seemed want very loud so i proceeded on. I was driving hwy speeds 70ish and everything seemed ok all the gauges looked normal. I stop at another store and the noise had gotten a little louder. It was still shifting into gear fine and the engine wasnt laboring or anything so i drove home. By the time i got home the nosie was sever iam not sure as to where its coming from if i rev the engine the nosie goes away and all seems good. But when i let off the throttle it comes down to idle and rattles like hell, but the engine seems to idle ok. When i put it into gear it gets worse, but the tranny is going into gear :shrug: . It kinda sound like when you leave a connetor off the valve cover gasket and it sound like s**t. The SES is not coming on either. Could it be the convertor??
Sorry its so long
Thanks in advance
Grummin is offline
post #2 of 14 (permalink) Old 10-28-2007, 03:09 AM Thread Starter
Grummin's Avatar
Maybe an injector going bad. But it doesnt smoke black or white
Grummin is offline
post #3 of 14 (permalink) Old 10-28-2007, 03:53 AM
Diesel Pro
Macktruckdriver's Avatar
Common thing to happen if its an automatic the flexplate cracks around the mounting bolts behind the metal ring and it fattles like **** untill you put it in gear or rev it up. Iv changed 5 and mine was cracked when i pulled my motor a few weeks ago.
Macktruckdriver is offline
post #4 of 14 (permalink) Old 10-28-2007, 03:53 AM
Diesel Pro
Common thing to happen if its an automatic the flexplate cracks around the mounting bolts behind the metal ring and it rattels like s**t untill you put it in gear or rev it up. Iv changed 5 and mine was cracked when i pulled my motor a few weeks ago.
post #5 of 14 (permalink) Old 10-28-2007, 04:08 AM
strokin now cummin later!
Orangepstroke's Avatar
of course it rattles its a diesel. just kidding, yeah i agree with macktruckdriver. it sounds like the flex plate. i have a buddy with a dodge and he broke the center out of his. sounds like yours is doin the same his did.
Erik, 2001 psd 4x4 lariat ext cab pulling truck
Ts 140hp 6pos chip, 100hp split shots, stealth 2 pump,h2e turbo, tranny, afe stage 2,
5" exhaust turbo back, 10" stack, 3.9k mod on a switch, shimmed fpr,hx crossover hose, tc lock up switch. Custom weight rack and ladder bars, f550 springs, custom paint,5%+15% window tint, clear lights,custom billet grille, very big stereo, 20x10 moto meatals wrap with 33x13.50x20 ss iroks
1996 2500 12v 2wd auto reg cab, flat bed, afc mods, sdx 140hp sticks, 4gsk, 60lbs springs, 191dv's, head studs, 16* timing, phat shaft 62/65/14 no plate, exhaust, intake, tanny, auto meter, adjustable overflow valve.
Singles Club #42
Orangepstroke is offline
post #6 of 14 (permalink) Old 10-28-2007, 04:03 PM Thread Starter
Grummin's Avatar
Would you be able to see it if its cracked out around the center. I looked at mine and rotated the engine and i didnt see any cracks from the bolts that hold the converter on or on the face of the plate. It did seem to wobble a little bit, dont know if thats normal
Grummin is offline
post #7 of 14 (permalink) Old 10-28-2007, 04:34 PM
Dually Club #3
jdydiesel's Avatar
You won't be able to see the cracks when it is together. I would also think that it should not wobble at all.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #8 of 14 (permalink) Old 10-28-2007, 05:44 PM Thread Starter
Grummin's Avatar
I think maybe its the flex plate i can shift the plate and the motor doesnt move all the time then it will catch and spin the motor.
Grummin is offline
post #9 of 14 (permalink) Old 10-28-2007, 07:31 PM
i would be safe to say there is your problem
Singles Club #42
post #10 of 14 (permalink) Old 10-28-2007, 07:41 PM
pontiacross's Avatar
I have seen a torque converter do that as well. I see you have a 99 and I think there was a service bulletin about that on the early superdutys. you might check you local ford dealer about it.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
