4 wheel drive - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by AllOut0606, this thread has received 20 replies and been viewed 1284 times.
post #1 of 21 (permalink) Old 10-28-2007, 07:12 PM Thread Starter
TDG Mafia Member # 70
Send a message via AIM to AllOut0606
4 wheel drive
My friend is telling me that i shouldnt have to lock the hubs to have 4 wheel drive. He thinks that i should be able to pull the 4x4 lever to put it in 4 wheel and power should go to the front wheels. but it doesnt do that.
i disagree with him. if that were true, then i shouldn't be able to spin my front driveshaft with my hand when the hubs are unlocked and the transfer case is set at 2 wheel drive. but i can.
someone shed some light for me.
2000 F250 7.3L CC Lariat 4X4 SB;
Performance:TS Performance Tuner///K&N Intake///Custom 5" Straight Pipe///6.0 Intercooler///B&M Trans Cooler///Foil Delete///Zoodad///CCV.
Interior: Autometer Gauges: Pyro, Trans, and Boost///Alpine In-Dash DVD Player///Audiobahn Sound System///Cobra 29 CB.
Exterior: Pro Comp 4" Lift///36" Super Swampers///16" wheels///Dual Hadley Peterbilt Horns///Viair 380c Compressor///Two 3 gallon air tanks///20% Tint///Warn Standard Hubs.
-Marshall-
AllOut0606 is offline
post #2 of 21 (permalink) Old 10-28-2007, 07:22 PM
Slow 6.0
he must be from dodge or chevy land where they have fulltime 4wd, meaning the front axle is always engaged and the front driveshaft is always spining, fortunatly for use we have automatic or manual locking hubs that disengage the front axle and driveshaft to save on gas and wear/tear. and we have the advantage to use lo range in 2wd
2006 F350 XLT 4x4
SICKS-O is offline
post #3 of 21 (permalink) Old 10-28-2007, 07:26 PM Thread Starter
f***ing A dude. Thank you, i thought i knew my vehicle. Thanks for your input.
-Marshall-
post #4 of 21 (permalink) Old 10-28-2007, 07:47 PM
pontiacross's Avatar
If you have a 4X4 switch in the dash it should go into 4X4 with out locking the hubs because the hubs have a vacuum line going to them that will lock them for you. the manual lock part is just there in case you have a vacuum leak, which is pretty common. now if you just have a lever in the floor I bet it doesnt have the vacuum part of it and you will have to lock them manually, but i have never been around a super duty with the lever to know for sure.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #5 of 21 (permalink) Old 10-28-2007, 08:04 PM Thread Starter
mine does not have shift on the fly, so yea i must lock them manually, lever on the floor.
but my friend just doesn't see how the hubs are not "attached" to the axle when the hubs are unlocked. its really annoying cuz he thinks he knows all about every car and he can't be wrong. So he tells me something is wrong with my truck.
Even with both hubs locked, does that necessarily mean that both tires will spin at the same time, like a LSD?
-Marshall-
post #6 of 21 (permalink) Old 10-28-2007, 08:33 PM
Slow 6.0
no because the front differential is "open" meaning the tires can spin at different speeds.
2006 F350 XLT 4x4
SICKS-O is offline
post #7 of 21 (permalink) Old 10-28-2007, 08:35 PM
The front axle on Superduties is a open differential. The only way you'll get both wheels to spin (mud, ice, steep hill, etc) is if you install lockers.
Pocket is offline
post #8 of 21 (permalink) Old 10-28-2007, 09:04 PM Thread Starter
ok, so it is an open differential. but then why is it "jumping" when i turn the wheels on asphalt? i realize that the wheels are turning faster then one another in a turn, but shouldn't the diff take care of that jumping?
-Marshall-
post #9 of 21 (permalink) Old 10-28-2007, 09:40 PM
StrokerDude's Avatar
does the front not even have limited slip on these trucks like the rear??
Alex C.
StrokerDude is offline
post #10 of 21 (permalink) Old 10-28-2007, 09:53 PM
That "jumping" on a sharp turn is actually the front axle u-joints binding up. Look behind the wheel hub assembly and you'll see the u-joint knuckle.
Nope, all open. I've tested it out many times. Found a few steep trails that my truck is spinning both rear tires as well as one of the front ones, and barely makes it up. Those are always fun. I'll need to get a video sometime of my truck doing that. It's cool to watch. Got the power, but the weight and tire grip sometimes doesn't want to cooperate.
Pocket is offline
