Air Bag Light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TowRig, this thread has received 5 replies and been viewed 686 times.
post #1 of 6 (permalink) Old 10-29-2007, 02:37 AM Thread Starter
Send a message via AIM to TowRig
Air Bag Light
My air bag light came on...uh oh whats the bad news? haha
AJ
2000 F-250 PSD Extended Cab Short Bed
-AutoMeter Gauges;Pyro, Tranny, Boost, Rear Diff, Fuel Pres, Air Pres.
-MBRP Turbo back, muffler delete
-AFE Stage II
-ITP Oil HPX Line
-CCV Mod
-AIH Delete
Trail rig: 1990 Jeep Cherokee, 4.0 I6, NP231 w/ SYE, Clayton Off road Long arm Suspension with coil conversion in rear, Full width Dana 44 up front(ARB, Warn Hubs and US Alloys Chromoly Axle shafts), full width Dana 60 in rear with Spool. 4.88 Gears all around, 36 inch Interco Bias Irok's, and lots of trail damage. :
TowRig is offline
post #2 of 6 (permalink) Old 10-29-2007, 08:25 PM
have to pull the codes to see what you got. . .mine came on and it was the light bulb in the passenger seat belt turn off switch that had burnt out. Haven't replaced it yet, i'm gonna try to solder a new one in and see if that fixes it.
-Brad Desatnik
trick76cj5 is offline
post #3 of 6 (permalink) Old 10-29-2007, 08:57 PM
plainredtruck's Avatar
Images: 11
Tell us how many times it blinks to see if it's the bulb or a clock-spring issue.
Mine's the bulb - for 3 years now it's blinked 2x then paused then 7x - too lazy/busy to fix it.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #4 of 6 (permalink) Old 10-30-2007, 12:56 AM Thread Starter
Ok ill check that out, thanks
AJ
-AFE Stage II
-ITP Oil HPX Line
-CCV Mod
-AIH Delete
TowRig is offline
post #5 of 6 (permalink) Old 11-01-2007, 04:17 PM
Defender Bob's Avatar
I never got around to fixing mine either. Mine was also the clock spring issue. I just really didnt want to take apart that airbag!
Defender Bob is offline
post #6 of 6 (permalink) Old 11-02-2007, 04:14 AM Thread Starter
Yea mine is all set I figured out what it was. Thanks guys.
AJ
-AFE Stage II
-ITP Oil HPX Line
-CCV Mod
-AIH Delete
TowRig is offline
