Exhaust Brakes... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdieselfreak, this thread has received 27 replies and been viewed 2012 times.
post #1 of 28 (permalink) Old 10-30-2007, 04:49 AM Thread Starter
Exhaust Brakes...
Do exhaust brakes make any kind of noise on a powerstroke?? Im bout to get an early '99 and the louder the better!!!
cumminsdieselfreak is offline
post #2 of 28 (permalink) Old 10-30-2007, 04:56 AM
pontiacross's Avatar
you can modify your exaust back pressure valve to work just like a exaust brake. you can probably do it for under $10 if you just want a switch in the dash to turn it on. it sounds like a jet engine at higher RPM's :Thumbup: if its cold enough for mine to kick on in the morning I'll try and get a video.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 28 (permalink) Old 10-30-2007, 05:01 AM
if you are looking for the loud jake brake sound you hear on the big rigs you won't hear it. The exhaust brakes on these are just a flap that closes off the exhaust. It will sound like rushing air and that's about it.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #4 of 28 (permalink) Old 10-30-2007, 05:02 AM Thread Starter
A vid would be awesome!
What brand of brake are u running??
post #5 of 28 (permalink) Old 10-30-2007, 05:03 AM Thread Starter
I know what an exhaust brake sounds like... I just want to know if certain brands are louder than others, thats all...
post #6 of 28 (permalink) Old 10-30-2007, 05:25 AM
I dont have a exhaust brake. I just have the stock exhaust back pressure valve still hooked up and a straight pipe. when the oil temp is below a certain temp it will close off to help the engine warm up faster.
it will sound basically the same if you modify it to make it a exhaust brake.
Ross
Tow Rig
post #7 of 28 (permalink) Old 10-30-2007, 05:29 AM Thread Starter
Oh i c now, i misread your post.. I have never seen this done before! Please get a vid if possible!
post #8 of 28 (permalink) Old 10-31-2007, 12:28 AM
sorry it was to warm out this morning to get it to come on. I try again tomorrow but it may be a few days before it cooles off enough again.
Ross
Tow Rig
post #9 of 28 (permalink) Old 10-31-2007, 12:34 AM
strokin now cummin later!
Orangepstroke's Avatar
is that what that noise is? mine did it with the factory down pipe and turbo. when it made that jet noise it had no power what so ever. i hated it. i figured it was a warmup feature of some sort. my dads 02 doesn't do it though. factory everything haha well its got factory down pipe.
Erik, 2001 psd 4x4 lariat ext cab pulling truck
Ts 140hp 6pos chip, 100hp split shots, stealth 2 pump,h2e turbo, tranny, afe stage 2,
5" exhaust turbo back, 10" stack, 3.9k mod on a switch, shimmed fpr,hx crossover hose, tc lock up switch. Custom weight rack and ladder bars, f550 springs, custom paint,5%+15% window tint, clear lights,custom billet grille, very big stereo, 20x10 moto meatals wrap with 33x13.50x20 ss iroks
1996 2500 12v 2wd auto reg cab, flat bed, afc mods, sdx 140hp sticks, 4gsk, 60lbs springs, 191dv's, head studs, 16* timing, phat shaft 62/65/14 no plate, exhaust, intake, tanny, auto meter, adjustable overflow valve.
Singles Club #42
Orangepstroke is offline
post #10 of 28 (permalink) Old 10-31-2007, 02:43 AM
your dads was either broke, unhooked, or you just couldn't hear it through a stock muffler. I am almost certan all of the 7.3's had them.
I acually kind of like the way it sounds and am going to miss it when I upgrade turbos, but I have a couple of friends that are also annoied by it and have unplugged theres. to each is his own I guess
for those interested into makeing in into an exaust brake here is a writeup about it. http://www.thedieselstop.com/content...xhaust%20Brake
sorry I thought there was a writeup here on the garage but I couldent find it, this one is written pritty good though.
Ross
Tow Rig
