Idm Help! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cummins0797, this thread has received 6 replies and been viewed 969 times.
post #1 of 7 (permalink) Old 10-30-2007, 09:41 PM Thread Starter
cummins0797's Avatar
Send a message via MSN to cummins0797
Exclamation Idm Help!
Ok i was getting ready to do the IDM mod and the closest resistor i have 68k and an 82k....will this hurt it any if i use either one? And by the way mine are carbon filmed but i didnt thank that would matter
2005 Silverado 2500-CC SB, 2wd, Auto, 4" Exhaust
cummins0797 is offline
post #2 of 7 (permalink) Old 10-30-2007, 10:08 PM
strokin now cummin later!
Orangepstroke's Avatar
yeah both of those are the wrong resistor you'll have to pull the inner finder down on the driver side to see what idm you have first to see wich idm you have. here is the instructions https://www.thedieselgarage.com/forum...ad.php?t=34377
but be careful you can fry the idm and have to get another one.
IDM-100 uses a 75.0k Ohm (75,000 ohm) 1/2 watt 1% tolerance Metal Film resistor
IDM-110 uses a 75.0k Ohm (75,000) 1/2 watt 1% tolerance Metal Film resistor
IDM-120 uses a 73.2k Ohm (73,200) 1/2 watt 1% tolerance Metal Film resistor
dieslpower97 seems to know quite a bit about it if you want to talk to him send him a p.m.
Erik, 2001 psd 4x4 lariat ext cab pulling truck
Ts 140hp 6pos chip, 100hp split shots, stealth 2 pump,h2e turbo, tranny, afe stage 2,
5" exhaust turbo back, 10" stack, 3.9k mod on a switch, shimmed fpr,hx crossover hose, tc lock up switch. Custom weight rack and ladder bars, f550 springs, custom paint,5%+15% window tint, clear lights,custom billet grille, very big stereo, 20x10 moto meatals wrap with 33x13.50x20 ss iroks
1996 2500 12v 2wd auto reg cab, flat bed, afc mods, sdx 140hp sticks, 4gsk, 60lbs springs, 191dv's, head studs, 16* timing, phat shaft 62/65/14 no plate, exhaust, intake, tanny, auto meter, adjustable overflow valve.
Singles Club #42
Orangepstroke is offline
post #3 of 7 (permalink) Old 10-30-2007, 10:18 PM Thread Starter
ive got everything out and know which resistor i need but i was wondering if the ones i have would do close to the same thang or what?
post #4 of 7 (permalink) Old 10-30-2007, 10:52 PM
the way i understand it the ones you have would'nt send it enough pulse and the other would be to much. i just got back from radio shack and i couldn't even find the right one there.
Singles Club #42
post #5 of 7 (permalink) Old 10-31-2007, 03:54 PM
Radio Shack only stocks the really common components but they can order almost anything. You can also check with an electronics repair shop. Keep in mind the IDM is a very expensive part so proceed with caution.
gpeyton is offline
post #6 of 7 (permalink) Old 10-31-2007, 04:46 PM Thread Starter
yeah i went to radio shack and i dont think they could order a 1% tol. but i decided to wait till i got the right one
post #7 of 7 (permalink) Old 10-31-2007, 05:00 PM
DIESEL FREAK
dieslpower97's Avatar
Order it from http://www.digikey.com/ and take the guess work out of it, pluss running around town isn't cheap when diesel in $3.33 a gallon. issed:
Be very specific with the resistor because IDM's aren't cheap.
1997 DIY intake, AFE exhaust, DP tuned, idm mod, fuel pressure mod, Stancor GPR, dual electric fans......and a whole lot more someday! SOLD!!!
2002 F350 Single Wheel Crew Cab XLT 4x4 165k
OBAMA SUCKS MAJOR
dieslpower97 is offline
