Just replaced my up pipes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by midwestoffroad, this thread has received 3 replies and been viewed 675 times.
post #1 of 4 (permalink) Old 10-31-2007, 12:40 AM Thread Starter
midwestoffroad's Avatar
Wow i just did the bellowed pipes on my 02,, everyone made it sound like it was going to be hard.
I did remove the turbo and pedistal and left the 4" down pipe in place.
only tool i needed was a 1/4 drive ratchet with a 5/16 or 8mm socket. and my torqure wrench.
I cut the 4 bolts off the flanges at the exhaust manifolds and the doughnut on the pass side up pipe was real loose so i just lifted the y and driver side pipe up and out and after cutting the 2 pass side it came right out as well..
only real time consuming part was the pass side lower bolt which with the bolts only loose in the exhaust manifolds allowed the uppipes to move to where the ratchet was able to tighten a 1/8 turn at a time but did it never the less. I am not done as i am finishing the EBV delete so whould button it all up tommorow..
midwestoffroad is offline
post #2 of 4 (permalink) Old 10-31-2007, 12:50 AM
TDG Mafia Member # 37
01blkf250's Avatar
Great glad to hear it's going well for you. Gene;Mafia
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
post #3 of 4 (permalink) Old 10-31-2007, 12:54 AM
strokin now cummin later!
Orangepstroke's Avatar
you made it sound easy. it took my from 5:30 one night until 3:30 the next morning. but i replaced the turbo, all innercooler pipes, y- pipe, up pipes and down pipe.
Erik, 2001 psd 4x4 lariat ext cab pulling truck
Ts 140hp 6pos chip, 100hp split shots, stealth 2 pump,h2e turbo, tranny, afe stage 2,
5" exhaust turbo back, 10" stack, 3.9k mod on a switch, shimmed fpr,hx crossover hose, tc lock up switch. Custom weight rack and ladder bars, f550 springs, custom paint,5%+15% window tint, clear lights,custom billet grille, very big stereo, 20x10 moto meatals wrap with 33x13.50x20 ss iroks
1996 2500 12v 2wd auto reg cab, flat bed, afc mods, sdx 140hp sticks, 4gsk, 60lbs springs, 191dv's, head studs, 16* timing, phat shaft 62/65/14 no plate, exhaust, intake, tanny, auto meter, adjustable overflow valve.
Singles Club #42
Orangepstroke is offline
post #4 of 4 (permalink) Old 10-31-2007, 04:57 AM
I was suprised as well at how easy my up pipe job went. The hardest part was putting the exhaust back together.
Stroked95 is offline
