Cant build more than 17.5lbs of boost help!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminspower121, this thread has received 10 replies and been viewed 830 times.
post #1 of 11 (permalink) Old 10-31-2007, 02:18 AM Thread Starter
Question Cant build more than 17.5lbs of boost help!!!
Hi my buddies got a 2000 7.3 with a airdog fuel system intake exhaust and stacked with edge and a boost fooler he also has a HTPI turbo the truck will start to cut out as soon as it hits 17.5lbs of boost how can we fix this problem and whats causing it? THANKS ALOT FOR ALL YOUR HELP!! :thanks:
cumminspower121 is offline
post #2 of 11 (permalink) Old 10-31-2007, 04:26 AM
pontiacross's Avatar
dose the check engine light come on, the boost fooler should have fixed that problem if it is working properly.
or it could also be a wastgate problem or just a boost leak.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 11 (permalink) Old 10-31-2007, 02:30 PM
are you saying he has stacked chips(or programs)
jebsurf is offline
post #4 of 11 (permalink) Old 10-31-2007, 04:45 PM Thread Starter
Yea hes running all edge programers and a boostfooler but as soon as it hits 17.5 psi it cuts the fuel and the check engine light dont come on
post #5 of 11 (permalink) Old 10-31-2007, 07:27 PM
CSIPSD's Avatar
Is he using the Edge for his gauges? I would tell you his boost fooler is only letting 17.5#'s thru and because the Edge use's the MAP sensor for its Boost reading thats why it stops there...
CSIPSD is offline
post #6 of 11 (permalink) Old 10-31-2007, 07:39 PM Thread Starter
so if he gets rid of the boostfooler would boost go up?
post #7 of 11 (permalink) Old 10-31-2007, 07:53 PM
laysonw's Avatar
seems like the boost fooler needs to be adjusted...
01 12.5" Icon, OUO Traction Blocks, Dynatrac Prosteer Balljoints, SpynTec Conversion, 40" Toyos, GTP38R, Isspro Guages, ORU Diff Covers, Hella 500s, AMP powerstep, Mini Me's, Heat Extractor Hood, custom paint, and BTS tranny!
New Truck Pics
Iraq War Heroes Tribute Page
laysonw is offline
post #8 of 11 (permalink) Old 10-31-2007, 08:00 PM
CSIPSD's Avatar
Should, What kind of boost fooler is it? An electric one (sounds like it is) or a blow off/regulator type?
The problem is without somekind of device on the MAP line, anything over 20-23#'s will set a SES light and the truck will defuel to lower the boost...
CSIPSD is offline
post #9 of 11 (permalink) Old 10-31-2007, 08:56 PM
1 find a garbage can
2 remove edge from truck
3 install edge into garbage can
4 light garbage can on fire
5 call dp tuner and order a real chip
gregrob is offline
post #10 of 11 (permalink) Old 11-06-2007, 04:09 PM
ccp
THE MASTER OF DISASTER
ccp's Avatar
Send a message via AIM to ccp
:iagree
but i would go with a garbage disposial instead of the trouble you would go through to light it on fire....
99.5 F-250 7.3 4X4 reg cab.
custom intake
dp tuner
suncoast/DTT Frankentrans
and a whole bunch of other crap i dont really need.
www.cabincreekpaintball.com
ccp is offline
