what is acceptable shaft play - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by midwestoffroad, this thread has received 8 replies and been viewed 1194 times.
post #1 of 9 (permalink) Old 10-31-2007, 09:11 AM Thread Starter
midwestoffroad's Avatar
like the title states what is acceptable shaft plat in the stock Garrett tubro on a 2002 7.3
midwestoffroad is offline
post #2 of 9 (permalink) Old 10-31-2007, 04:37 PM
Super Moderator
John_G's Avatar
Side to side (in/out) it must not touch the housing, same with up/down.
Modern turbos are WAY "looser" than older ones, it is completely normal to have now, what used to be completely unacceptable amounts of play. No, they did not loosen the specs to save $$$, the turbos are that much better.
I vote for LIBERTY!
John_G is offline
post #3 of 9 (permalink) Old 10-31-2007, 04:44 PM
strokin now cummin later!
Orangepstroke's Avatar
:iagree one thats still in good shape should slightly move or not move at all.
Erik, 2001 psd 4x4 lariat ext cab pulling truck
Ts 140hp 6pos chip, 100hp split shots, stealth 2 pump,h2e turbo, tranny, afe stage 2,
5" exhaust turbo back, 10" stack, 3.9k mod on a switch, shimmed fpr,hx crossover hose, tc lock up switch. Custom weight rack and ladder bars, f550 springs, custom paint,5%+15% window tint, clear lights,custom billet grille, very big stereo, 20x10 moto meatals wrap with 33x13.50x20 ss iroks
1996 2500 12v 2wd auto reg cab, flat bed, afc mods, sdx 140hp sticks, 4gsk, 60lbs springs, 191dv's, head studs, 16* timing, phat shaft 62/65/14 no plate, exhaust, intake, tanny, auto meter, adjustable overflow valve.
Singles Club #42
Orangepstroke is offline
post #4 of 9 (permalink) Old 10-31-2007, 05:21 PM
DIESEL FREAK
dieslpower97's Avatar
I had a 2000 7.3 and it only had 55,000 on it and it had some play, so it is typical, higher mileage will have obviously have more play.
1997 DIY intake, AFE exhaust, DP tuned, idm mod, fuel pressure mod, Stancor GPR, dual electric fans......and a whole lot more someday! SOLD!!!
2002 F350 Single Wheel Crew Cab XLT 4x4 165k
OBAMA SUCKS MAJOR
dieslpower97 is offline
post #5 of 9 (permalink) Old 10-31-2007, 06:00 PM Thread Starter
Mine spins freely and doesnt have hardly any thrust play (in/out) but side to side it seems excessive. but doesnt touch the housing. but i dont think you could fit a dollar bill between the fin and housing
post #6 of 9 (permalink) Old 10-31-2007, 08:17 PM Thread Starter
grabbed my dial indicator. with 1 finger the play is .001 but with 2 fingers and slight pressure max is about .020.. again no end play in and out.. i am going to assume this is fine and put it back on..
post #7 of 9 (permalink) Old 10-31-2007, 08:55 PM
You have nothing to worry about.
My turbo could probably be measured in 32nd's of an inch
Eric
Dually Club Member #53
racehauler is offline
post #8 of 9 (permalink) Old 10-31-2007, 09:09 PM
gregrob is offline
post #9 of 9 (permalink) Old 10-31-2007, 11:25 PM Thread Starter
thats exactly what i needed to read... sure enough i find in now also while searching threw the stickies on the main 7.3 page here.
