drive line - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cowboy1092, this thread has received 2 replies and been viewed 667 times.
post #1 of 3 (permalink) Old 10-31-2007, 11:39 PM Thread Starter
drive line
i have been going through a lot of u joint what could be causing this?
cowboy1092 is offline
post #2 of 3 (permalink) Old 11-01-2007, 12:38 AM
Any number of things. Is your truck lifted? If so did you put tapered blocks in the back? Is your driveshaft clocked properly? Did you shim your carrier bearing when you did the lift if you have one? Need more info.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #3 of 3 (permalink) Old 11-01-2007, 01:21 AM
DIESEL FREAK
dieslpower97's Avatar
Your driveshaft could be out of balance also. Check to see if there are any weights on it.
1997 DIY intake, AFE exhaust, DP tuned, idm mod, fuel pressure mod, Stancor GPR, dual electric fans......and a whole lot more someday! SOLD!!!
2002 F350 Single Wheel Crew Cab XLT 4x4 165k
OBAMA SUCKS MAJOR
dieslpower97 is offline
