99 7.3 just a few questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 7.3johnnyB, this thread has received 7 replies and been viewed 605 times.
post #1 of 8 (permalink) Old 11-02-2007, 05:35 AM Thread Starter
I have a 99 7.3 with intake 4in down pipe 5in back ts 6 bank chip . when im pulling a trailer mainly up inclines with the egt around 1000 and boosting around 15psi to 25psi depending some times it sounds like its blowing off and trying to intake at the same time and the turbo sounds like its skipping engine sounds the same and will still acclerate,all hp settigngs but stock. any thoughts ?? what are "normal" egt's for pulling moderate loads no 10000 pound loads. Is 30-32psi to much for a factory turbo and engine ??
7.3johnnyB is offline
post #2 of 8 (permalink) Old 11-02-2007, 05:39 AM
pontiacross's Avatar
sounds like a turbo surge problem, an ats ported housing and wicked wheel should fix that, but if you want to run 30+psi very much you should just upgrade turbos because that is going to wear on that stocker.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 8 (permalink) Old 11-02-2007, 05:41 AM
I should have asked is that a early or late 99? the turbos are different and the diagnosis may be different
Ross
Tow Rig
post #4 of 8 (permalink) Old 11-02-2007, 05:48 AM Thread Starter
The date on the door is early 99 but the pcm was replaced with one with the letters nvk which was not upgraded for performance not sure if that has any signifacance to the prob
post #5 of 8 (permalink) Old 11-02-2007, 07:46 AM
It's turbo surge. And 32psi will kill the stocker
gregrob is offline
post #6 of 8 (permalink) Old 11-02-2007, 02:36 PM Thread Starter
thanks guys
post #7 of 8 (permalink) Old 11-02-2007, 02:44 PM Thread Starter
looks like ats sells housings for 99.5 powerstrokes any ideas ??
post #8 of 8 (permalink) Old 11-02-2007, 04:06 PM
CSIPSD's Avatar
http://www.beansdieselperformance.com/99-03turbo.htm
Bottom of the page... about your only option with out swapping everything to a late 99 set up.
Or you can go with an H2e type set up.
CSIPSD is offline
