Injectors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by powerstroke7.3, this thread has received 3 replies and been viewed 522 times.
post #1 of 4 (permalink) Old 11-03-2007, 06:04 AM Thread Starter
Injectors
I have a 1997 powerstroke and was wondering what kind of injectors to put in it and just an overall opinion of what to do. i have a superchip and a 4 inch turbo back exahust. what do you guys recamend. i want some black smoke!!!
powerstroke7.3 is offline
post #2 of 4 (permalink) Old 11-03-2007, 07:37 AM
OK well other than black smoke what are your plans for the truck? What do you mainly use the truck for? How much power do you want? What future mods do you plan on?
The first step would be some 160cc injectors with stock nozzles. These are by far the most versitle because without a chip they will run exactly like a stock truck. Great for needing emissions testing and stuff like that along with heavy towing where you can turn they way back down if need be. The next step would be 160cc injectors with bigger nozzles. This will get the fuel out of the injectors faster and will make a little more power. Either will get your EGTs up there so if you do a lot of heavy towing I'd recomend an intercooler as well. If all you do is jazz around unloaded then and intercooler won't be as necessary. Next step from there would be some hybrids which are considerably more fuel and will tax your fuel system and turbo. If you plan on other things like an oil system, bigger turbo, etc and want to make a lot more power then you could go with B codes. Also what is your budget? Obviously the more you have done to the injectors the more it's going to cost. As you can see there are a LOT of factors in deciding what is going to fit your needs best.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #3 of 4 (permalink) Old 11-03-2007, 06:18 PM
I think theirs a couple companys that make a 130cc Injectors, sorta between stock and Stage 1s(160cc)
A little less taxing on yer stock fuel and oil systems, and yer superchip:Thumbup:
ckbed is offline
post #4 of 4 (permalink) Old 11-03-2007, 10:18 PM Thread Starter
I'm using the truck for a little bit of pulling but mostly a driver. i want more power out of the injectors.
