Fuel Bowl Delete Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6_Myles, this thread has received 6 replies and been viewed 1076 times.
post #1 of 7 (permalink) Old 12-23-2007, 03:53 AM Thread Starter
I be Architect'n
What would be the disadvantage of running a fuel bowl delete with only a high-flow prepump filter and no post pump? I am still redesigning my veg. oil system and for the sake of oil temp. and purge times it would be better not to have one.
My first thought is if the stock pump explodes your injectors are toast, but does this really happen?
2K3 EXCURSION 7.3L 4x4 EDDIE BAUER 107K miles as of 06-13-07
AFE Stage II / 4" MBRP exhaust / DP-Tuner F5 (Stock, 60hp Tow, 80hp Econo, 120hp race & High Idle) / Quadzilla Commander/ATS Housing
Running homebrewed BioDiesel and custom SVO kit for 70k miles.:Thumbup:
Misc. Mods: ZooDad/By-Pass Oil Filter/203* T-Stat/Coolant Filter/HPX/CCV Reroute/Tranny Filter/Foil Delete/Stereo Stuff/ITP Reg Return/Non-EBPV Pedistal and Exhaust Housing/Adjustable Waste Gate Controller/
"If you love your motorcycle, set it free. If it comes back to you it was probably a high-side."
I'LL TRY TO KEEP UP, BUT THE EXCURSION IS A BIG GIRL AND BIG GIRLS DON'T LIKE TO MOVE FAST.
6_Myles is offline
post #2 of 7 (permalink) Old 12-23-2007, 07:04 PM
There are two problems. One being as you stated, no way to catch debris if the pump wears/fails. The second being you will have to run at least a 5 micron filter pre-pump. This puts a bunch of vacuum on the inlet side of the pump causing premature pump failure and making the possibility of cavitation much higher.
It is best to have a 10 to 15 micron pre pump filter and a 2 micron post pump so that you have great filtration from the post pump and great water separation from the pre pump, along with the pre pump filter keeping all the debris from getting to the pump.
Eric
Dually Club Member #53
racehauler is offline
post #3 of 7 (permalink) Old 12-24-2007, 05:09 PM
There are quite a few people running a set up like your talking about. I'm actually running a dahl 150 pre filter, it has like a 2 micron rating and is a water seperator. The important thing is to find a pre filter that is rated for the amount of fuel your fuel pump can flow at the stated pressure. Debris from a toasted fuel pump could find it's way to your injectors if it does go out, that is a good point, but a number of people are running that very set up, and i haven't heard of any failures due to it.
-Brad Desatnik
trick76cj5 is offline
post #4 of 7 (permalink) Old 12-24-2007, 06:01 PM
Pre pump filters smaller than 10 micron have been know to cause premature pump failure. The Dahl is one of the best for using the smaller micron pre pump but there are still problms with too much vacuum when the filter gets a little dirty.
Filter change interval needs to be more frequent as you go lower on the micron rating.
Eric
post #5 of 7 (permalink) Old 12-24-2007, 09:28 PM
anyone tried this setup and if so what are your opinions????
http://www.itpdiesel.com/store.php?c...on=show_detail
ksttac is offline
post #6 of 7 (permalink) Old 12-24-2007, 10:37 PM
I haven't used it nor do I know the specifics about the filter that they use but ITP does a lot of research before he makes up fuel system kits. I would have no problem buying that kit to put on a truck.
Eric
post #7 of 7 (permalink) Old 12-25-2007, 05:12 AM
Correct, it is important to have a vaccuum gauge on the filter so you can keep an eye on the condition of the filter.
-Brad Desatnik
