7.3l blow off valve?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Big Bad Stroker, this thread has received 4 replies and been viewed 2018 times.
post #1 of 5 (permalink) Old 01-03-2008, 07:17 PM Thread Starter
Ive got a 00' f250 7.3l and for about the last week here my truck wont build any boost until i get down the road for about 5-8 minutes. it sounds like air is just blowing in the engine compartment. could this be my blow off valve sticking?
Big Bad Stroker is offline
post #2 of 5 (permalink) Old 01-03-2008, 07:20 PM
JUCK FEEP
Beer Mod's Avatar
Sounds like the choke, mine sounds like a jet for the first 5 min if it's cold enough out side.
Singles Club #80
Ridin' High #32
02 F-350 7.3PSD CC Lariat Off RD PKG 8" lift 38x15.50 MT MTZ's 4.10 R&P Edge juice W/Attitude and Evolution 12K HID's 4" intake 4" strait pipe F450 HD Trans 5 Star Converter w/lock Tugger 2 and more....
99.5 Audi A4 1.8T Quattro Sport pkg 5spd GT2871R FMIC MBC 22psi 3" intake 19x8.5's JL Audio system and more.....
07 Rock Crawler Fuel injected 350 sm465 Dual Toyota cases Rockwells Billstein Coilovers PSC Hydro Ouverson brakes 44x18.50 TSL's 230:1 Crawl Ratio
My Buggy Videos
http://www.youtube.com/user/notquite.../1/WiawMf_296A
http://www.youtube.com/user/notquite...14/1ER50syjDco
http://www.youtube.com/user/notquite.../2/k4qSNjUd27g
Beer Mod is offline
post #3 of 5 (permalink) Old 01-03-2008, 07:33 PM
Choke is not the correct word or concept at all. "choke" is a butterfly valve in the intake a carb'ed gas engine that closes to pull in more fuel during a cold start. Try again.
Anyway, what you're describing sounds very much like your Exhaust Back Pressure Valve, or EBPV. It's a hydraulically actuated butterfly valve in your exhuast that your engine closes to raise backpressure to help the engine warm up in cold weather. Yours sounds like it may be sticking, as mine will usually open right up when I press the accelerator, and close back when I'm at even throttle, coasting, or idling. The actuator rod gets all gunked up and even leaks sometimes. A lot of people just delete the whole thing if they've got the turbo out.
If you do a title search on EBPV, you'll get enough hits to keep you busy for days.
Good luck,
Paul
edit: BTW, we dont have a blowoff valve. They're needed for turbo'd gas engines to allow boost to escape when the throttle plate closes...and we ain't got no stinkin throttle plates.
2002 Arizona Beige F250 Ext Cab Short Bed. 7.3L 6spd 4x4 140k
2" leveling kit, 285/75 Mastercraft AT2's,Napa BFF, DiPricol Pryo/Boost, DP F5 NS/stock/hi/40/80/120/140agg-lope, Toolbox, Audio goodies, IH shiftknob
muffler delete, CCV reroute, AIH/Foil delete,
paulkeith is offline
post #4 of 5 (permalink) Old 01-03-2008, 07:52 PM
JUCK FEEP
Beer Mod's Avatar
my bad :bow:
Singles Club #80
Ridin' High #32
My Buggy Videos
Beer Mod is offline
post #5 of 5 (permalink) Old 01-03-2008, 08:16 PM
If the guy knew what a choke was, and you called it a choke, he'd be sent in the 100% wrong direction, looking for problems in the intake rather than exhaust. Not trying to bust you up...just use the right words. Attention to detail is key, and wrong advice is worse than no advise. Anyway, I dont want to start a pissing match in this guy's thread. End hijack.
