help on 2001 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97STROKER_08, this thread has received 3 replies and been viewed 831 times.
post #1 of 4 (permalink) Old 01-23-2008, 01:05 AM Thread Starter
help on 2001
One of my buddies has an 01 F-250 that keeps dying. They already had the cam sensor replaced by ford a week ago. The only code it throws is p1670 EF Feedback not detected. What does this mean?:shrug:
97STROKER_08 is offline
post #2 of 4 (permalink) Old 01-23-2008, 06:05 PM
rock removal technition
you can try to replace the idm relay, it may be intemittant,
any other codes with the 1670?
double-s-diesel is offline
post #3 of 4 (permalink) Old 01-23-2008, 09:11 PM Thread Starter
where is the idm relay? p1670 is the only code it shows. Thanks
post #4 of 4 (permalink) Old 01-24-2008, 03:21 PM
IDM relay is in the fuse box under the hood, not shure off hand which relay.
other possibility is bad fuse, bad relay, open circuit between idm and cpu, cpu.
next steps involve a breakout box to check the coninuity of wires from cpu to idm
