vaccum seal ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tm0231009, this thread has received 10 replies and been viewed 758 times.
post #1 of 11 (permalink) Old 03-15-2008, 06:16 PM Thread Starter
TDG MAFIA #101
tm0231009's Avatar
vaccum seal ?
Is there any way to replace the ball joints without taking off or damaging the vaccum seals?
On the hunt for a 7.3 preferably CC or Ext. Cab SB...Let me know of any deals.
1979 Ford F-100 Ranger, Custom dark purple and silver paint, 15"x8"117 Series Eagle Alloy's, Winston tires, 400 cu - Work In Progress!! http://www.cardomain.com/ride/2570291
"The only dumb question is the one not asked."
TDG MAFIA MEMBER #101
TDG SINGLES CLUB MEMBER #88
tm0231009 is offline
post #2 of 11 (permalink) Old 03-15-2008, 10:14 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
I did mine and i don't think so.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #3 of 11 (permalink) Old 03-15-2008, 11:10 PM Thread Starter
TDG MAFIA #101
tm0231009's Avatar
Thats good, I was hoping there was a way to work around them. I know that if I were to change the u-joints on the axles, that I would, but I didn't know about the ball joints. Thanks.
post #4 of 11 (permalink) Old 03-16-2008, 12:05 AM
midwestoffroad's Avatar
your going to have to pull the axle shafts and just using 2 pry bars the seals should come out without damage.
midwestoffroad is offline
post #5 of 11 (permalink) Old 03-16-2008, 02:06 AM
Agreed. Getting the old seals off is the easy part. The new seal is a little tough though. You could take your stub axles to a repair shop and they can press them on for a few bucks. You can also put them on yourself, with a seal driver or pipe, like I did. However, I have manual hubs, so I didnt have to worry about vacuum leakage as with other trucks.
99fordtruckguy is offline
post #6 of 11 (permalink) Old 03-16-2008, 06:05 PM Thread Starter
TDG MAFIA #101
tm0231009's Avatar
So I do have to pull the axle shafts in order to get the ball joints out? That's just it though, the two trucks I am doing this to have the switch so I can't have any leakeage. Thanks for the replys guys.
-- on edit -- How much do the seals cost in case of damage?
post #7 of 11 (permalink) Old 03-16-2008, 09:34 PM
I bought my parts from ford all the seals 235.00 out the door.
I could not remove my with out destroying the seals and the axle run through the spindles.
I can send you some pdf files on an 2003 if thats close enough.
Bill
5" SS Tip
post #8 of 11 (permalink) Old 03-17-2008, 02:36 AM
My two new front vacuum/hub seals were 48.00 each from Ford.
The two axle shaft dust seals were 25.00 each from Ford.
If you go to www.powerstrokeshop.com and look at there seal/ball joint kit, there is a link to a good write up of the install process for ball joints and seals. It is full of pretty good pictures as well.
post #9 of 11 (permalink) Old 03-18-2008, 03:27 AM Thread Starter
TDG MAFIA #101
tm0231009's Avatar
Hey thanks for all the replies fellas. Do I need to replace the dust seals if they are not damaged? I will probably order the vaccum/hub seals because I doubt I can get them out without damaging them.
post #10 of 11 (permalink) Old 03-18-2008, 04:10 AM
Removing any of them without damage can be the hard part. The rubber is usually brittle. The dust seals are also somewhat pressed on by hand, so there is a little force needed sometimes to remove them which most likely will damage them. That being said, you dont have to remove the dust seals when you replace the ball joints. They can simply stay on the axle shafts as you do the other work. Mine were obviously deteriorated before disassembly, so I replaced them. My thinking on this matter is that when is the next time you will have the front end apart like this and have good access to the dust seals. I personally would go ahead and replace them, since your in there anyway. They are really quick and easy to replace. I think you can find the dust seals for aroud 10 bucks each from another company (National?). The vacuum seals are a Ford only seal to my knowledge.
