How can I make it stop from... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by GilroyRacing, this thread has received 19 replies and been viewed 3163 times.
post #1 of 20 (permalink) Old 03-23-2008, 11:09 PM Thread Starter
TDG SinglesClub Member#90
I have a 96 Crew Cab with an 8ft bed, and it wheel hops like crazy.
What can I do to make the wheel hop stop?
1996 Ford F350, 7.3 PSD, crew cab, 8ft(Line X'd) bed, 4x4, 5 speed manual, 4.11 gears, 285/75/16 Nitto Terra Grapplers, 222,000 miles, DP-Tuner Chip NS 1200 high idle stock 60Tow 80econo 120Race, 3x4" down pipe, 4" exhaust straight piped with 5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers, Garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
GilroyRacing is offline
post #2 of 20 (permalink) Old 03-23-2008, 11:50 PM
Get a short bed
Just kiddin, i cant help ya on that but good luck!
cumminsdieselfreak is offline
post #3 of 20 (permalink) Old 03-24-2008, 12:00 AM
a set of quality ladder bars will do you wonders...
early '99 converted to late '99 F-350 dually, 4x4, 4 door, long bed, 6 speed. Midwest transmissions 05+ zf-6 transmission with their short throw shifter and SB clutch. Rosewood 180cc with 80% nozzles, Termy modded 17* HPOP, International bellowed up pipes, fs-2500, DP Tunes. A few other things here and there...
dually club member.. Why replace 5 tires when you can replace seven? I like my training wheels...
calebgriffin31 is offline
post #4 of 20 (permalink) Old 03-24-2008, 12:08 AM Thread Starter
where can I get a set if ladder bars?
post #5 of 20 (permalink) Old 03-24-2008, 12:12 AM
hold on i will see if i can help
96 F350 crew cab long bed. DIY green filter intake 7 inch stacks. stock height .275,000 and still truckin
96 stroker is offline
post #6 of 20 (permalink) Old 03-24-2008, 12:17 AM
Member in Learning!
You could always go the cheap route and put a bunch of sand bags in the bed of the truck.....
Or this way...
http://www.thepickupguy.com/graphics/ShurTrax.jpg
Its mostly for winter traction...
Or like these guys...You wouldn't have to worry about anyone stealing your truck!
http://www.defenselink.mil/DODCMSSha...-0416K-002.jpg
But +1 on the ladders..
'99 F350 XLT, 7.3 PSD Crew Cab, LB, 4x2, Auto. DIY Intake.
Just learnin as I go!
jmbstudios is offline
post #7 of 20 (permalink) Old 03-24-2008, 12:25 AM Thread Starter
^^^hahahaha
post #8 of 20 (permalink) Old 03-24-2008, 01:52 AM
www.suspensionconnection.com has a kit i think, atleast i was going to get som from them when i was thinking to buying them. someday when i get my million other projects done ill just make some.
Ford certified diesel tech.
96 F350 reg cab, black. stage Is, exhaust intake TS 6pos chip and a few small tricks. tranny built up a little and a billet converter. 4in lift 35 bfg muds.
3" cowl hood, billet grille, bumper with billet grille and fog lights, 10in drop rear bumper with lights and a dropped hitch.
90 mustang lx 347 afr 185s, vic jr efi, aeromotive fuel system, c4 , 4.10 31 spline, tube k member and control arms coil overs and control arms in the rear, 10pt cage.
05 f250 red ext cab grey int, 4x4 6.0 suncoast tranny, ats 275cc injectors, studs, aeromotive fuel system, turbonetics 70mm ceramic coated turbo, dual 5 inch stacks turnned out. ALL PARTS FOR SALE
fordboyyfm is offline
post #9 of 20 (permalink) Old 03-24-2008, 02:55 AM
Sounds like a good way to put a lot of sand on the road! Not sure how weight is going to keep the axle from warpping. I've had some major issues with this at the track like here. Best way to cure it is with traction bars. The ones with a solid mount at the frame and one mount on the axle work OK. But for the best all out you want two mounts on the axle with a shackle of some sort on the frame. This will totally eliminate all axle wrap.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
post #10 of 20 (permalink) Old 03-24-2008, 03:30 AM
Member in Learning!
He didn't say it was from racing like the video, so I assumed it might have been from going through some sand dunes or something like that..
Didn't know it was axle warping.:shrug: My bad.
