serious help needed please... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by drbalazo, this thread has received 6 replies and been viewed 676 times.
post #1 of 7 (permalink) Old 03-26-2008, 05:18 AM Thread Starter
I have a 2002 F350 7.3 and have a problem with it. It keeps making the "CPS" failure symptoms. It dies when running and won't start for a while (10 - 30 minutes) and then it runs again but dies again. I have changed the CPS sensor 5 times in the past 4 days and it keeps doing the same thing. I have no CEL and I hooked up the scanner and reads nothing and there are no codes saved in the memory either. I tried another PCM and that did not fix the problem. I am running out of ideas here. Any help would be greatly appreciated.
drbalazo is offline
post #2 of 7 (permalink) Old 03-26-2008, 06:00 AM
2tonePSD's Avatar
is your fuel bowl half full???? if it is it could be a low pressure pump. not to sure but it is just in idea
RIP.......
96 F-350 Regular cab: 5" to 6" exhaust. autometer Z series a pillar pod for gauges. Window tint.
2tonePSD is offline
post #3 of 7 (permalink) Old 03-26-2008, 02:03 PM
It's your IPR. Mine did the exact same thing. CPS-like stalling and no codes.
Pocket is offline
post #4 of 7 (permalink) Old 03-26-2008, 03:51 PM Thread Starter
Injection Pressure Regulator? If yes, then I will defenitely check for that. Hopefully thats the propblem. Thank you very much for your input.
drbalazo is offline
post #5 of 7 (permalink) Old 03-26-2008, 03:55 PM
Yep, it's on the back of the HPOP. Check the nut on the top first to see if it's loose. Sometimes that's the cause. If not, then the IPR itself is sticking. A few have cleaned it and had no issues, some others cleaned it and still had problems. If you do buy a new one, check Ebay for a better price than the dealership.
Pocket is offline
post #6 of 7 (permalink) Old 03-26-2008, 04:20 PM Thread Starter
Will do, thanx again, bud.
drbalazo is offline
post #7 of 7 (permalink) Old 03-26-2008, 06:12 PM
It's very likely it's just the O-rings on the IPR. The o-ring kit is like $15.00 vs. over $100 for a new IPR. I'd check those first.
466 on #2 only
739 with NČO
13.544 in 1/4 mi!
Yeah I can keep up!:Thumbup:
gtspowerstroke is offline
