Intermittent shaking through the steering wheel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by john, this thread has received 8 replies and been viewed 1108 times.
post #1 of 9 (permalink) Old 03-28-2008, 06:21 PM Thread Starter
I have started to get a intermittent shaking through the sterring wheel while braking. This happens only about 25% of the time and I am not able to relate it to a certain speed or road condition. I figure its in the braking system, maybe a warped rotor. On other cars I have felt the rotors through the brake pedal, but never through the sterring wheel. What do you guys think?
Thanks
John
john is offline
post #2 of 9 (permalink) Old 03-28-2008, 06:23 PM
Check your ball joints..
Slated4Greatness is offline
post #3 of 9 (permalink) Old 04-02-2008, 11:54 PM Thread Starter
Thanks
Thanks, my problem was a bad sterring stabilizer.
john is offline
post #4 of 9 (permalink) Old 04-03-2008, 02:38 AM
TDG MAFIA #101
tm0231009's Avatar
How did you find that out? Just wondering because my truck is doing the same thing, and I just figured it was warped rotor, so I would aprreciate it so I could check into something. Thanks
On the hunt for a 7.3 preferably CC or Ext. Cab SB...Let me know of any deals.
1979 Ford F-100 Ranger, Custom dark purple and silver paint, 15"x8"117 Series Eagle Alloy's, Winston tires, 400 cu - Work In Progress!! http://www.cardomain.com/ride/2570291
"The only dumb question is the one not asked."
TDG MAFIA MEMBER #101
TDG SINGLES CLUB MEMBER #88
tm0231009 is offline
post #5 of 9 (permalink) Old 04-03-2008, 03:04 AM
Dually Club #3
jdydiesel's Avatar
You might want to also check those ball joints, they are famous for giving you the Death Wobble.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #6 of 9 (permalink) Old 04-03-2008, 03:09 AM
TDG MAFIA #101
tm0231009's Avatar
I jacked the front of the truck and and had no play in any which way. That's why I am confused as to what is giving me a vibration, and that is why i figured it was a warped rotor.
post #7 of 9 (permalink) Old 04-03-2008, 03:15 AM
Dually Club #3
jdydiesel's Avatar
A warped rotor will always give you that wobble. Check all your tie rods and drag links for play you should find something that isn't right.
Jason
post #8 of 9 (permalink) Old 04-04-2008, 12:57 AM
Rotors are bad ,,,most likely seized up slides or stuck rotors
Most likely when they are al ready hot...
Rick....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
www.fordtransmissioncure.com
Special thanks to RacerX USA
action4478 is offline
post #9 of 9 (permalink) Old 04-05-2008, 06:06 PM
Had the very same issue and lived with it until one emergency stop almost shook the steering wheel of my hands.......
I replaced the galled caliper pins with anodized units used lifetime warranty pads and now smooth as can be. I'd go that route before turning rotors. I was very surprised that my rotors were still true but yes they held up!
C-man
Chinookman is offline
